Rattling AC compressor
5.0 V10 50v biturbo - 571 bhp
rs6danbar
Post by rs6danbar » Thu Jan 04, 2018 10:38 pm
AC compressor is rattling when ECON is turned off, perfectly quite when turned on.
Just accidently turned it off and sounded just like timing chains being slack at first, heart stopped beating for a min :lol:
Not planning on fixing it as long as it doesnt sound bad when engaged as im never using it off anyway, but i guess the engine has
come out for this one aswell, would be my 4th time in that case :audibash:
Anyone else experienced it? shouldnt it be like the other way?
Jim Haseltine
Re: Rattling AC compressor
Post by Jim Haseltine » Fri Jan 05, 2018 9:33 am
It won't be the compressor if the noise is when it's switched off, it'll be the clutch on the compressor pulley. As long as there's room to get the specific puller in place it should be possible to change it without dropping the engine.
If you always use the AC the clutch will run for ages (because it's always engaged) so it's probably not urgent.
