Alarms
A20LEE
Re: Alarms
Post by A20LEE » Wed Dec 20, 2017 8:12 pm
Neilb76 wrote:
Sun Nov 26, 2017 9:29 pm
mikep99 wrote:
Sun Nov 26, 2017 12:35 pm
If anyone's looking for an installer in the North West - Autowatch or Clifford, I can recommend Paul @ www.pl-autotek.com
He's based in St. Helens and installed a Clifford system for me a couple of years ago - no problems at all, left my car with him for a couple of days so he could take his time over it...
Mike
Ive been chatting to him as well nuve chap and knows his stuff. I feel the pandora is a better ststem when i have done my home work
How did your install go Neil?
Neilb76
Re: Alarms
Post by Neilb76 » Thu Dec 21, 2017 8:55 am
Perfect not a problem. It went of last night due to a sensor so waiting for a call back today. But very happy with yhe install.
pule333
Re: Alarms
Post by pule333 » Thu Dec 21, 2017 11:58 am
Neilb76 wrote:Perfect not a problem. It went of last night due to a sensor so waiting for a call back today. But very happy with yhe install.
May I ask, what sensor?
My tilt is triggered periodically. Even on almost lowest setting. Usually at night.. a little confused.
RS4 B7 aka Vinnie
Neilb76
Re: Alarms
Post by Neilb76 » Thu Dec 21, 2017 1:02 pm
This one and it was at night as well wired
A20LEE
Re: Alarms
Post by A20LEE » Thu Dec 21, 2017 2:44 pm
The app looks different to mine. Is yours Pandora Pro?
Bund
Re: Alarms
Post by Bund » Thu Dec 21, 2017 5:39 pm
I had my install by Anthony as I'd said i didn't want the guy who caused issues with the other members car.
Almost went perfectly but couldn't get the remote start to work as Anthony wasn't aware that i was having it and didn't have the firmware to get it working, he installed it all but car would shut down after a few seconds so he removed all the equipment and said they would send someone back out to reinstall at a later date. We haven't confirmed a date of that yet but i'm sure it will happen, i wasn't keen on the remote start at first but as my daily driver getting it warmed up in the winter is needed. I went for the new silver package but had to turn the internal sensor off as i sometime leave my dogs in the boot.
Anthony was here from about 10-7 as he tried in vain to get the remote start to work, I don't know how installers are doing this without a garage, the light went at 4pm and it would of been a nightmare for him if he was outside(bloody cold too).
Merc 560 SEC
Merc E320 Sportline Cab
Toyota LJ70 LC
Neilb76
Re: Alarms
Post by Neilb76 » Thu Dec 21, 2017 11:17 pm
Yes pandora silver
pule333
Re: Alarms
Post by pule333 » Fri Dec 22, 2017 12:53 am
Bund wrote:I had my install by Anthony as I'd said i didn't want the guy who caused issues with the other members car.
We had similar issue.
Is this when you start with a key normally? Remote start should work fine.
It’s the immobiliser. Basically what’s happening is that the immobiliser box that connects to the clutch switch (needed for remote start and contains your spare key decoder) backfeeds signal to the ring. And because you have your key present at same time, car thinks it’s been cloned and shuts of. You should be able to see SAFE on the dash next to Odometer. We installed a diode in-line and it fixed the problem. A sort of one way resistor. So it let’s signal from box to clutch switch but not other way round.
RS4 B7 aka Vinnie
Bund
Re: Alarms
Post by Bund » Fri Dec 22, 2017 6:52 am
From what I see the problem was that when he used the fob to remote start the car would fire up but then after several seconds switch off? He couldn’t get round it and said it was to do with firmware.
I would like it though so I’m going to get them back in January to fit it correctly.
Merc 560 SEC
Toyota LJ70 LC
Lukes3
Re: Alarms
Post by Lukes3 » Fri Dec 22, 2017 6:20 pm
Has anyone had there “tag” system incase someone takes the keys from you?
A20LEE
Re: Alarms
Post by A20LEE » Fri Dec 22, 2017 6:33 pm
Yes I do, went for the top of the range system.
Neilb76
Re: Alarms
Post by Neilb76 » Fri Dec 22, 2017 10:37 pm
I have the transponder i keep in my wallet. Just incase the keys are stolen or dragged from the car..
Users browsing this forum: No registered users and 199 guests
