My B6 Supercharged Stage 1+ RS4 build thread...
iconic78
Re: My B6 Supercharged Stage 1+ RS4 build thread...
Post by iconic78 » Tue Sep 19, 2017 8:41 pm
iconic78
Post by iconic78 » Tue Sep 19, 2017 8:43 pm
iconic78
Post by iconic78 » Tue Sep 19, 2017 8:48 pm
So after a very long break and a hot summer(62c was the hottest) now working to finish the car completely before we move countries.
Fitting a P3 boost gauge, uprating to a 340 LPH LPFP(already upgraded the HPFP’s) in anticipation of the built engine I’m going to do to have a crack at the Magic 800!
Also fitting a killer chiller.
The car will be finished albeit the built engine by the end of the month in time to be shipped.
MrHilario
Post by MrHilario » Wed Sep 20, 2017 8:13 am
Doesn't look bad at all :thumbs:
1.4 Fiesta (Silver)
2.8 VW Bora V6 4motion (Blue)
4.2 Audi RS4 B7 Avant (Black)
iconic78
Post by iconic78 » Wed Sep 20, 2017 8:29 am
MrHilario wrote:Doesn't look bad at all :thumbs:
It’ll look a lot better once completed. Played around with the coding for the solar sunroof and few other options such as the speed bong, seatbelt chime etc
MrHilario
Post by MrHilario » Tue Nov 21, 2017 10:02 am
Update please! at least some more pics!
Laziest build thread ever! (only joking :beerchug:)
1.4 Fiesta (Silver)
iconic78
Post by iconic78 » Tue Nov 21, 2017 1:12 pm
Car is off the road to fix a few issues with the bodywork and fit the killer chiller.
Deflapped the IM and fitted a P3 gauge.
J130YCE
Post by J130YCE » Fri Nov 24, 2017 7:59 pm
Great build, keen to understand more about the killer chiller, does it cool incoming air or help keep engine or charger temps lower?
BMW M2 Comp
RS4 Supercharged
Current Abarth 500c Two tone Grey and Mint - a modified go-cart.
Current T5 180 bi-turbo - modified, Reimo pop top, ABT kit, Caravelle 7 seats, going on 'air' this summer
Gone RS4 B7 Avant MRC, MK5 R32, 205 GTI, Mk1 golfs... plus some other poor souls
iconic78
Post by iconic78 » Fri Nov 24, 2017 10:40 pm
J130YCE wrote:Great build, keen to understand more about the killer chiller, does it cool incoming air or help keep engine or charger temps lower?
The KC is really if your running a SC or FI engine. It’s main focus is lower IAT’s by cooling the charge cooler water temp to around 0-4c thus allowing you to run more boost safely without fear of detonation.
It does this by utilising the AC system and allowing the coolant to pass through
All SC cars suffer from heat soak so if you can reduce temps you’ll benefit from more power. This is often overlooked.
The KC is about the size of a loaf of bread and weighs around 2kgs dry.
J130YCE
Post by J130YCE » Fri Nov 24, 2017 10:54 pm
Mine's Supercharged and oil temps, therefore engine temps are higher
BMW M2 Comp
RS4 Supercharged
iconic78
Post by iconic78 » Fri Nov 24, 2017 11:03 pm
J130YCE wrote:Mine's Supercharged and oil temps, therefore engine temps are higher
Then you’d benefit from a KC. There on sale at the moment as it’s Black Friday/Thanksgiving weekend.
Oil temps shouldn’t really be an issue as the stock OC does the job ok.
Yours is a TTS unit which should be water cooled? I’ve never seen one in person hence why I ask.
Where my SC sits is where you’d place the KC.
J130YCE
Post by J130YCE » Fri Nov 24, 2017 11:12 pm
Yes mine is a TTS, and is water cooled. can you send me a link to the black Friday deal.
incidental what is the HP gain - approx?
BMW M2 Comp
RS4 Supercharged
iconic78
Post by iconic78 » Fri Nov 24, 2017 11:30 pm
Did you get the pm’s?
iconic78
Post by iconic78 » Fri Nov 24, 2017 11:31 pm
Also there’s loads of YT Vids on the KC and what/how it works etc
iconic78
Post by iconic78 » Fri Nov 24, 2017 11:36 pm
J130YCE wrote:Yes mine is a TTS, and is water cooled. can you send me a link to the black Friday deal.
The TTS unit have a limit to the amount of power they can push out which is around 680, so I believe you can squeeze out another 40.
The KC would be on my list along with the pumps; both LP and HP.
Users browsing this forum: Google Adsense [Bot] and 159 guests
