It’ll look a lot better once completed. Played around with the coding for the solar sunroof and few other options such as the speed bong, seatbelt chime etcMrHilario wrote:Doesn't look bad at all
The KC is really if your running a SC or FI engine. It’s main focus is lower IAT’s by cooling the charge cooler water temp to around 0-4c thus allowing you to run more boost safely without fear of detonation.J130YCE wrote:Great build, keen to understand more about the killer chiller, does it cool incoming air or help keep engine or charger temps lower?
Then you’d benefit from a KC. There on sale at the moment as it’s Black Friday/Thanksgiving weekend.J130YCE wrote:Mine's Supercharged and oil temps, therefore engine temps are higher
The TTS unit have a limit to the amount of power they can push out which is around 680, so I believe you can squeeze out another 40.J130YCE wrote:Yes mine is a TTS, and is water cooled. can you send me a link to the black Friday deal.
incidental what is the HP gain - approx?
Users browsing this forum: No registered users and 366 guests
