jockthedog wrote: ↑Tue Nov 14, 2017 8:16 am140kgs of heavy, that is! I needed a engine hoist to move it around myself.
Gearbox reconditioned
Re: Gearbox reconditioned
Was it that much? I remember it being a bit on the heavy side, but don't recall needing the engine hoist - and I'm no weight lifter either - more of a racing snake.
- simonpoulton
Yeah it takes two people to lift it into a back of a car. Made a dolly up for mine out of wood and some wheels which was good for shifting it around. Just put it straight onto the dolly when disconnecting from engine and then transferred onto a pallet on my own since it’s the right height.
Past: R56 Mini Cooper S
- jockthedog
I had to get the thing from my workshop to a trailer, and nobody was around to help.
Used a pallet as a kinda ramp, as the workshop is up a step, and I'd also made a dolly which was very handy indeed.
IMG_0601 by jockthedog, on Flickr
IMG_0604 by jockthedog, on Flickr
And then having dropped the pallet off at the garage, found out that this was the wrong fecking trousers and had to repeat the process in reverse.
It's still in my garage.
And if you can dead lift one of these, you're more of a racing anaconda!
I'm a racing worm and I can only just get a B5 6speed above my waist. 80kg. Still a lot more than I weigh tho!
IMG_0604 by jockthedog, on FlickrAnd then having dropped the pallet off at the garage, found out that this was the wrong fecking trousers and had to repeat the process in reverse.
- jockthedog
also came in handy when I had to stand the thing on its end and didn't fancy putting all the weight on the rear diff...
IMG_0545 by jockthedog, on Flickr
If that’s carpet on the floor of your workshop you sir are living the dream!!jockthedog wrote:also came in handy when I had to stand the thing on its end and didn't fancy putting all the weight on the rear diff...
- jockthedog
The workshop was once someone else's band practice room and as such has double plasterboard and insulation all round and yes, some very oily carpet on the floor.
I do intend to rip it up eventually and replace it with plastic like you see on the left.
Best part was it came with double sockets every 3 feet round the walls. Walls which are also covered with carpet!
Means I can turn up the amp to 11 and not bother anyone.
I have the exact same crane and balance beam - good kit.
jockthedog wrote: ↑Tue Nov 14, 2017 7:42 pmalso came in handy when I had to stand the thing on its end....
Users browsing this forum: Shoppinit, Steve2003rs6 and 331 guests
