Gearbox reconditioned
Mɐʇʇ
Re: Gearbox reconditioned
Post by Mɐʇʇ » Tue Nov 14, 2017 8:59 am
Was it that much? I remember it being a bit on the heavy side, but don't recall needing the engine hoist - and I'm no weight lifter either - more of a racing snake.
jockthedog wrote:
Tue Nov 14, 2017 8:16 am
140kgs of heavy, that is! I needed a engine hoist to move it around myself.
simonpoulton
Post by simonpoulton » Tue Nov 14, 2017 9:39 am
Yeah it takes two people to lift it into a back of a car. Made a dolly up for mine out of wood and some wheels which was good for shifting it around. Just put it straight onto the dolly when disconnecting from engine and then transferred onto a pallet on my own since it’s the right height.
Past: R56 Mini Cooper S
jockthedog
Post by jockthedog » Tue Nov 14, 2017 7:36 pm
I had to get the thing from my workshop to a trailer, and nobody was around to help.
Used a pallet as a kinda ramp, as the workshop is up a step, and I'd also made a dolly which was very handy indeed.
ImageIMG_0601 by jockthedog, on Flickr
ImageIMG_0604 by jockthedog, on Flickr
And then having dropped the pallet off at the garage, found out that this was the wrong fecking trousers and had to repeat the process in reverse.
It's still in my garage.
And if you can dead lift one of these, you're more of a racing anaconda!
I'm a racing worm and I can only just get a B5 6speed above my waist. 80kg. Still a lot more than I weigh tho!
jockthedog
Post by jockthedog » Tue Nov 14, 2017 7:42 pm
also came in handy when I had to stand the thing on its end and didn't fancy putting all the weight on the rear diff...
ImageIMG_0545 by jockthedog, on Flickr
Jayjay101
Post by Jayjay101 » Wed Nov 15, 2017 7:35 am
jockthedog wrote:also came in handy when I had to stand the thing on its end and didn't fancy putting all the weight on the rear diff...
If that’s carpet on the floor of your workshop you sir are living the dream!!Image
jockthedog
Post by jockthedog » Wed Nov 15, 2017 8:43 am
The workshop was once someone else's band practice room and as such has double plasterboard and insulation all round and yes, some very oily carpet on the floor.
I do intend to rip it up eventually and replace it with plastic like you see on the left.
Best part was it came with double sockets every 3 feet round the walls. Walls which are also covered with carpet!
Means I can turn up the amp to 11 and not bother anyone.
Mɐʇʇ
Post by Mɐʇʇ » Wed Nov 15, 2017 9:27 am
I have the exact same crane and balance beam - good kit.
also came in handy when I had to stand the thing on its end....
Users browsing this forum: No registered users and 538 guests
