Should i remove the centre resonator? NOISE!
gdgd
Post by gdgd » Wed Oct 25, 2017 9:52 am
Hey guys,
I feel the car is a little quiet so have toyed with doing a centre res delete. I'm not 100% sure I like the noise in videos - sounds a bit tinny and very raspy...
1. Does it sound better than a resonated car in person?
2. Does it drone like crazy at 70/80mph?
Thanks!!
pule333
Re: Should i remove the centre resonator? NOISE!
Post by pule333 » Wed Oct 25, 2017 9:52 am
1. Yes
2. No
RS4 B7 aka Vinnie
gdgd
Post by gdgd » Wed Oct 25, 2017 9:54 am
To the point... I like it OK.
Votes:
Yes x 1
No x 0
Post by MikeFish » Wed Oct 25, 2017 11:42 am
You mean compared to a standard OEM exhaust rather than a milltek resonated? If so then yes it sounds much better which is why people do it. Mine has a rasp but I like that.
And I get no noticeable drone at any speed.
And disconnect the valves for even more noise.
irn_bru_ce
Post by irn_bru_ce » Wed Oct 25, 2017 11:18 pm
People talk about the miltek having a drone at 2-2.5k , and it does, but when just cruising round 30 zones, I only ever need 1.5k, and on the motorways at 80mph your above the drone, so to me its irrelevant. Sounds brilliant above 5.5k on sport mode, thats all you need to know basically
RS4LAD
Post by RS4LAD » Thu Oct 26, 2017 3:37 am
Milltek valved non res is what you want!
After hitting 5.5k the sounds are amazing.
I get no drone on motorways between 70-80
coffey555
Post by coffey555 » Thu Oct 26, 2017 7:55 am
Just do the res delete on the stock exhaust, replace with straight pipes, it sounds lovely with no drone.
The car will sound so much better without you looking like a massive knob, just the right side of loud.
I had a guy in a Seat Leon come past and tell me that the car sounded utterly beautiful once. This did happen in Dunfermline though so there was a good chance the driver was high on drugs at the time.
Misano Red RS4 B7 Avant
jonytek
Post by jonytek » Thu Oct 26, 2017 4:20 pm
Res delete and gut the pre cats. I've done this and am very happy with it. It gives a very nice level of rasp but with no drone.... Just doing the res i was quite disappointed TBH.
BUILD THREAD
IG: @bad_rs_4
Post by MikeFish » Thu Oct 26, 2017 4:55 pm
I only did the res delete after I already gutted the pre cats so can't comment on the sound of the res delete with pre cats in place still but I know that the pre cat delete with oem exhaust was very quiet and the res delete made all the difference for me but maybe Jony is right that you need the combo to make it great.
jonytek
Post by jonytek » Thu Oct 26, 2017 7:13 pm
Same thing in a different order isn't it Mike?
BUILD THREAD
IG: @bad_rs_4
Post by MikeFish » Thu Oct 26, 2017 7:36 pm
Yes but I didn't think the pre cat delete made much difference to the noise.
Rodney007
Post by Rodney007 » Fri Oct 27, 2017 9:55 am
Primary and secondary cat delete + valve mod = best
The resonator adds a very nice deep tone. Remove it and from the outside they sound like a raspy peice of sh*&
neil_f
Post by neil_f » Fri Oct 27, 2017 11:57 am
Mine has standard exhaust but with centre resonator replaced with straight pipe. Sounds good and is still refined on motorway etc. Must admit when I drove ones completely standard I was a bit disappointed with the noise. Would definitely recommend removing the centre silencers!
amdaman
Post by amdaman » Wed Nov 01, 2017 2:42 am
Just recently removed mine and one of the cats - the sound is a lot better than before (imo)
https://www.youtube.com/watch?v=dYASRWp74V0&sns=em
Users browsing this forum: Google [Bot] and 150 guests
