Anyone spot the problem?
Frustratedracer
Re: Anyone spot the problem?
Doesn't do it on WOT, so will have to do what i did for the first set of logs but let it run out to the redline.
Will do some g'box logs as well in case something shows up.
Make sure you log the ignition retarding. Or advance, rather.
If it doesn't do it on WOT then that suggests something in closed loop mode is causing issues.
While you're there, have a look at the current trim levels (measuring group 30 or 32 IIRC).
Once you've got a good log, clear your fault codes (even if there are none) and try immediately the same pull. Clearing dtc also resets trim values to zero.
Also whip off the DVs and test them. It's a 10 min job. You can test by sucking on the vac hose connection and making sure the valve moves.
When's the last time the plugs were changed and what with?
Frustratedracer
Plugs were changed less than 1k ago - NGK PFR7Q
Might be worth retorquing them. They can come a bit loose if not torqued properly. Long shot, but a no cost thing to try. Are you sure they are genuine plugs and not Ebay specials?
Frustratedracer
100% jen-you-ine
Going to be a busy evening for me!
Frustratedracer
Okay Dokay, spent this evening doing more logs.
Couldn't get to the red line as i would have run out of road and it was changing up into 5th anyway at these speeds.
If anyone would care to have a look and tell me what they think it would be much appreciated.
- Attachments
- Engine log 1.xls
- (31.5 KiB) Downloaded 49 times
- Engine log 2.xls
- (29.5 KiB) Downloaded 54 times
- Engine log 3.xls
- (30.5 KiB) Downloaded 54 times
- Engine log 4.xls
- (39 KiB) Downloaded 45 times
Frustratedracer
Added Lambda/Fuel trim log
- Attachments
- Lambda & Fuel trim.xls
- (52 KiB) Downloaded 45 times
In engine log 1 there are 2 instances where requested boost suddenly drops to a very low value then back up. At the same time, the ECU closes the throttle and the air flow is subsequently reduced. Pretty much straight away the requested boost goes back to max and the throttle opens again.
I suspect that this is the hesitation that you are experiencing, but I don't have the information of the accelerator pedal position in those logs to see if you lifted off or not.
The ECU may be responding to a request to reduce power from the gearbox or ABS / ESP module. Or responding to some knocking. The retardation values are quite high for cylinders 5 to 8, especially. Not sure if this is related to the difference in MAF values where one is reading less air intake. You say you've replaced them, but there is still a bigger difference that I would expect between banks. I would swap the MAFs with each other to eliminate them as a cause of the imbalance.
Also, your trim is showing that the mixture is being weakened. Maybe you've got a small boost leak that's resulting in overfuelling. It's not unknown for the hoses to develop a pinhole that can let varying amounts of air leak depending on boost. This could result in mixture oscillation and excessive knock. Maybe do a pressure test?
There's also a bit of overshoot on the boost. This might point to sticky N75. That could lead to an overboost problem, but that normally leaves a DTC. Not always though.
Somewhere you can log the requests to the ECU to limit torque. Might be in the gearbox TCU. I don't think it's likely that it'll be the ESP unless you're logging in slippery conditions.
Perhaps you could log the boost vals, accel pedal position, throttle angle and retardation for 5-8.
Did you test the DVs? Did you try a pull immediately after resetting the trim values?
Frustratedracer
Shopp,
Those dips in log 1 are me lifting the throttle slightly as i was trying not to cause it to downchange to 3rd.
Shouldn't really have posted that one up - i added Engine log 4 as that is a far smoother throttle application.
If i do a graph of the trim data the lambda control sensor lines seems a bit peaky at the start of the run, is this normal? Does lambda control have any bearing on what i am experiencing?
N75 was replaced a couple of years ago but might still be dodgy.
Yes, tested DV's and all seems fine, could hear/feel the valve closing.
Forgot to reset the trims.
Will do more logs tonight and post up.
Thanks for your help so far, much appreciated.
There's a button to leave a marker in the log when something happens. It would be really useful if you could mark when the issue occurs.
Frustratedracer
Will do
Frustratedracer
OK Shopp,
Some more logs done tonight.
One thing that's perplexing me with all this - why don't i get any of these issues when car is in tiptro or paddle shift?
Is this a gearbox or TC issue that is leading me on a merry dance?
- Attachments
- Engine Log 1.xls
- (16 KiB) Downloaded 54 times
- Engine Log 2.xls
- (16 KiB) Downloaded 55 times
- Engine Log 3.xls
- (14 KiB) Downloaded 61 times
- Gearbox Log 1.xls
- (14 KiB) Downloaded 46 times
- Torque.xls
- (13 KiB) Downloaded 42 times
- Trim 1.xls
- (13 KiB) Downloaded 44 times
- Trim.xls
- (15 KiB) Downloaded 40 times
Shopp is the guru on diagnosing this type of thing - you've got the right guy helping you.
Interestingly, the logs you just posted still show the same behaviour for what appears to be consistent accelerator pedal.Frustratedracer wrote: ↑Thu Aug 03, 2017 3:13 pmThose dips in log 1 are me lifting the throttle slightly as i was trying not to cause it to downchange to 3rd.
The markers are useful. You can see that the rpm rate of increase stalls which will be the hesitation you are feeling. In many of the logs the required boost also drops to zero above atmo at the same time.
I would say that it's the ECU responding to a request to limit torque from the gearbox.
The gearbox log shows that at your marker the calculated torque is higher than anywhere else at about 700. This would suggest to me that the TCU is preparing to change gear because the torque value is too high for the gear you are in. Or that the TCU is requesting torque limiting to protect the box.
This is usually a problem in cars that have been remapped but which haven't had the TCU modified to accept the higher torque values.
The interesting thing is that it doesn't do it in tiptro. This suggests to me that your TCU has been modified to deal with the extra torque in tiptro mode but possibly not in D. I suspect there are a bunch of different parameters for each mode.
I am fairly sure there is a measuring block value in the ECU for the flag to reduce torque at TCU's request. It might be in the TCU measuring blocks, can't remember. Try to find it and see if it corresponds to your hesitation. Maybe log it and mark it.
Who did your TCU? Viper?
Users browsing this forum: Bing [Bot] and 267 guests
