Milltek help
Milltek help
Had milltek cat back fitted yesterday and although i love the sound the exhaust is producing, there is a knocking when on bumpy roads. I have today jacked car up and can see the front section (mesh type part) on drivers side is virtually touching the bottom corner of the gearbox. The flange is bolted perfectly aligned to the cat, so can't see how it can be adjusted. Has anyone else seen this or got a picture of where front section joins cat from under car when there's was fitted?
Re: Milltek help
100% sure it is that part that is causing the knocking?
I suppose in your case it is that, but for what it is worth...altough S6 avant here....on mine the problem was on the rear. The left exhaust pipe almost touches one of the side cross brace in the last section of exhaust. Never know it is also that...or combo.
If not, not sure how your issue can be fixed.
Re: Milltek help
Front section as been manufactured wrong, flange welded at wrong angel resulting in the pipe touching gear box.dasquade wrote: ↑Sun Jun 04, 2017 1:58 pm100% sure it is that part that is causing the knocking?
Re: Milltek help
I had a slight knock with my milltek
Tight right hand turns...lateral movement.
Probably shitty milltek quality control.
RS6 C8 carbon black(merlin)
Panamera Turbo S e hybrid
RS6 C8 launch edition
R8 V10 plus
C7 RS6 PE dynamic pack plus
C7 RS6
Porsche Panamera Turbo
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW Passat 130d 4 motion
VW bora 150pd
Ford Mondeo Ghia X V6
Ford Focus zetec
Rover 214!!
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
Re: Milltek help
Front section has been replaced by milltek. New section fitted to car and exactly the same issues the section sits about a 1mm away from gear box.
Contacted milltek again who said send it back and they will check it on there jig or travel 150 miles to my nearest authorised milltek fitter for them to have a look at.
I'm not happy with there response so have contacted supplier to return the full system which I'm gutted to do as I love the noise the car now makes.
Now looking at following a few on here and have front boxes removed for the sports exhaust.
Re: Milltek help
Well you know what my answer would be??
Send milly back
Get front and middle boxes took out £200 max
As near as dam it to a non res milly.
Send milly back
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
Re: Milltek help
Milltek is going back
Only a couple of exhaust fabricators in Cumbria which I've phoned today. Neither filled me with confidence regarding removal of front and middle boxes!!
Can you recommend anywhere in north east?
Re: Milltek help
I used
Exhaust A Fix
Based in Darlington
Drove in at 1pm....all done by 3:30!
Top job
Exhaust A Fix
Based in Darlington
Top job
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
Re: Milltek help
Picture of removed boxes
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
Re: Milltek help
Car lighter now also as added bonus! Lol
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
Re: Milltek help
Bit odd that both exhausts didn't fit good, wild guess, but maybe one OEM downpipe is not perfect and the issue is there instead of the milltek?
Again, wild guess.....
Re: Milltek help
I thought the same but the OEM sports exhaust fits perfectly in the centre of the channel about 30mm off the gear box
Re: Milltek help
[img][/img]
Re: Milltek help
Strange one as there are obviously hundreds of cars out there running Milltek trouble free. I never had any issues with mine but admittedly I didn't check the clearance either. I doubt very much it's a design issue or Milltek would have been aware of it and redesigned it, something must be different about your particular car.
MY16 Audi RS6
