Turbo bypass fault HELP!!
rr56kal
Post by rr56kal » Tue May 16, 2017 10:30 pm
Only recently I have felt the car have a loss of power the fault comes up as a turbo bypass anybody had the same problem
Brooner
Re: Turbo bypass fault HELP!!
Post by Brooner » Wed May 17, 2017 7:23 am
i would go directly to stealers
Leo-RS
Post by Leo-RS » Wed May 17, 2017 11:57 am
Most likely an issue with the diverter valve (Dump valve) - may just be a sensor issue, or may be the actual valve.
Should be an easy fix but one for the dealers if its still under warranty (And Standard)
MY16 Audi RS6
rr56kal
Post by rr56kal » Wed May 17, 2017 12:00 pm
Not standard and we have changed both of the (dump values) and fault still pings up when you run diagnostic
Leo-RS
Post by Leo-RS » Wed May 17, 2017 12:23 pm
What was the actual code?
The N249 solenoids control the dump valves, it may be an issue with the sensors that control them rather than the valves themselves.
Also N75 valve controls the turbo waste gates, may be an issue there. I would have hoped to see if any of those numbers were in the fault code somewhere to help detect the issue but that's where I'd be looking first.
MY16 Audi RS6
rr56kal
Post by rr56kal » Wed May 17, 2017 12:29 pm
rr56kal
rr56kal
Post by rr56kal » Wed May 17, 2017 12:30 pm
That's the fault code that it's showing on the diagnostic but with changed the complete thing sensors the lot
Thanks everybody been much help
