Only recently I have felt the car have a loss of power the fault comes up as a turbo bypass anybody had the same problem
Turbo bypass fault HELP!!
Re: Turbo bypass fault HELP!!
i would go directly to stealers
2018 B9 RS4 Navarra Blue
2013 B8 RS4 Sepang Blue
2007 B7 RS4 Avant Sprint Blue
2001 B5 RS4 Nogaro Blue
1993 B4 S2 Avant laser Red
Most likely an issue with the diverter valve (Dump valve) - may just be a sensor issue, or may be the actual valve.
Should be an easy fix but one for the dealers if its still under warranty (And Standard)
MY16 Audi RS6
Not standard and we have changed both of the (dump values) and fault still pings up when you run diagnostic
What was the actual code?
The N249 solenoids control the dump valves, it may be an issue with the sensors that control them rather than the valves themselves.
Also N75 valve controls the turbo waste gates, may be an issue there. I would have hoped to see if any of those numbers were in the fault code somewhere to help detect the issue but that's where I'd be looking first.
MY16 Audi RS6
That's the fault code that it's showing on the diagnostic but with changed the complete thing sensors the lot
Thanks everybody been much help
