Which spacers and where to get them?
J66kco
Re: Which spacers and where to get them?
Post by J66kco » Sat May 13, 2017 8:08 am
Pgj0hns0n wrote:
Fri May 12, 2017 6:48 pm
J66kco wrote:
MikeFish wrote:
Tue May 09, 2017 2:32 pm
Should have ordered from Virdee to ensure right size spacers and bolts
Surely they will get right ones as they took my reg and contacted H&R in Germany to order?? I've also ordered springs and milltek with them so easier one order
@J66kco - mines now booked in 23rd May to be lowered 20mm with 10mm up front / 15mm rear spacers.
I'll take some before and after pictures to share with you.
That would be go mate. Can you see what's involved in changing spring with having drc, as I'm getting told different things. Some say straight forward others problematic
J66kco
Knobby
Post by Knobby » Sun May 14, 2017 8:24 pm
Spacers fitted.. pleased with the results..
I went for 12mm Front and 15mm Rear..
Pgj0hns0n
Post by Pgj0hns0n » Sun May 14, 2017 8:38 pm
That's nice. Looks really good. Is it lowered as well?
Knobby
Post by Knobby » Sun May 14, 2017 8:48 pm
Cheers.. Nope just on air..
skirs6
Post by skirs6 » Sun May 14, 2017 9:08 pm
I went for 10mm all round and happy with that. Don't want it any lower
J66kco
Post by J66kco » Sun May 14, 2017 9:27 pm
Looks very nice, so much better than standard. 20mm drop and it will be perfect
nuwanda
Post by nuwanda » Mon May 15, 2017 3:50 am
Nice. What brand are those please?
Phil
Mazda Eunos 800M, Mazda Tribute 3.0, Toyota Harrier 2.4, Lexus IS250 Deluxe, Audi Q7 3.6, Golf MKV R32, Audi MK2 TT 3.2, BMW X1 xDrive25i, Audi S5 Sportback, MB C63 Estate, Audi RS6
Tadass910
Post by Tadass910 » Mon May 15, 2017 12:00 pm
Post by MikeFish » Mon May 15, 2017 12:49 pm
It says 30mm and they normally quote per axle so 15mm per side. I can double check against the boxes I have at home later.
J66kco
Post by J66kco » Mon May 15, 2017 1:28 pm
Mine were ordered the same as the pictures direct from h&r so all should be good
Tadass910
Post by Tadass910 » Mon May 15, 2017 3:36 pm
Ok thanks Mike, please check
So one wheel 15 mm and on all wheels 15mm spacers?
Knobby
Post by Knobby » Mon May 15, 2017 9:17 pm
Mine are H&R ordered from Virdee Autos (Virdee Autos ~ 07950-526592) as suggest by most on here.
No rubbing yet.. Wouldn't go any wider on the rear, the tyre is almost past the rim.
They are 15mm each side..
Post by MikeFish » Mon May 15, 2017 10:02 pm
Just checked, yes my 15mm spacers have 30mm on the box. And my 12mm spacers have 24mm on the box.
DragonRR
Post by DragonRR » Mon May 15, 2017 10:18 pm
Mike do you have the part numbers for those two sets? And.. do you know if they'll fit a PE with standard wheels, not lowered?
Polo 895cc 81|Datsun thing 83|Astra Van 1.3 85|Escort 1.6 87|XR2 88|Renault 5 Trbo 90|Renault 21 Trbo 93|XR2i 16v 94|Jag XJ6 99|BMW M3 E36 01
BMW 328i E46 04 & Honda VFR750|BMW M3 E46 06|Jag XK8 07 & Honda CBR600RR|BMW 645CSI E63 08|BMW M6 E63 09|Audi S5 10|BMW M5 F10 12 blk
Audi RS6 C7 14 Dayt Grey|Vxhall Corsa 1.2LE Yell|Golf R 15|C63s Ed 1 Coupe|Porsche 911 991 Turbo S 14 Saph Blue|RS6 PE 16 Nogaro Blue|AMG GTS 16 Blue|M5 Comp White 18|Current: M5 Comp Snap Blue 19|Audi R8 V10+ Blk 18
