That would be go mate. Can you see what's involved in changing spring with having drc, as I'm getting told different things. Some say straight forward others problematic
Which spacers and where to get them?
Re: Which spacers and where to get them?
Spacers fitted.. pleased with the results..
I went for 12mm Front and 15mm Rear..
That's nice. Looks really good. Is it lowered as well?
Cheers.. Nope just on air..
I went for 10mm all round and happy with that. Don't want it any lower
Looks very nice, so much better than standard. 20mm drop and it will be perfect
Nice. What brand are those please?
Phil
Mazda Eunos 800M, Mazda Tribute 3.0, Toyota Harrier 2.4, Lexus IS250 Deluxe, Audi Q7 3.6, Golf MKV R32, Audi MK2 TT 3.2, BMW X1 xDrive25i, Audi S5 Sportback, MB C63 Estate, Audi RS6
It says 30mm and they normally quote per axle so 15mm per side. I can double check against the boxes I have at home later.Tadass910 wrote: ↑Mon May 15, 2017 12:00 pmWhich size spacers are those:
http://imageshack.com/a/img922/7820/WjRJgb.jpg
http://imageshack.com/a/img923/1074/7hqw4d.jpg
Mine were ordered the same as the pictures direct from h&r so all should be goodMikeFish wrote: ↑Mon May 15, 2017 12:49 pmIt says 30mm and they normally quote per axle so 15mm per side. I can double check against the boxes I have at home later.Tadass910 wrote: ↑Mon May 15, 2017 12:00 pmWhich size spacers are those:
Ok thanks Mike, please checkMikeFish wrote: ↑Mon May 15, 2017 12:49 pmIt says 30mm and they normally quote per axle so 15mm per side. I can double check against the boxes I have at home later.Tadass910 wrote: ↑Mon May 15, 2017 12:00 pmWhich size spacers are those:
J66kco wrote: ↑Mon May 15, 2017 1:28 pmMine were ordered the same as the pictures direct from h&r so all should be goodMikeFish wrote: ↑Mon May 15, 2017 12:49 pmIt says 30mm and they normally quote per axle so 15mm per side. I can double check against the boxes I have at home later.Tadass910 wrote: ↑Mon May 15, 2017 12:00 pmWhich size spacers are those:
So one wheel 15 mm and on all wheels 15mm spacers?
Mine are H&R ordered from Virdee Autos (Virdee Autos ~ 07950-526592) as suggest by most on here.
No rubbing yet.. Wouldn't go any wider on the rear, the tyre is almost past the rim.
They are 15mm each side..
Just checked, yes my 15mm spacers have 30mm on the box. And my 12mm spacers have 24mm on the box.
Mike do you have the part numbers for those two sets? And.. do you know if they'll fit a PE with standard wheels, not lowered?
Polo 895cc 81|Datsun thing 83|Astra Van 1.3 85|Escort 1.6 87|XR2 88|Renault 5 Trbo 90|Renault 21 Trbo 93|XR2i 16v 94|Jag XJ6 99|BMW M3 E36 01
BMW 328i E46 04 & Honda VFR750|BMW M3 E46 06|Jag XK8 07 & Honda CBR600RR|BMW 645CSI E63 08|BMW M6 E63 09|Audi S5 10|BMW M5 F10 12 blk
Audi RS6 C7 14 Dayt Grey|Vxhall Corsa 1.2LE Yell|Golf R 15|C63s Ed 1 Coupe|Porsche 911 991 Turbo S 14 Saph Blue|RS6 PE 16 Nogaro Blue|AMG GTS 16 Blue|M5 Comp White 18|Current: M5 Comp Snap Blue 19|Audi R8 V10+ Blk 18
Users browsing this forum: No registered users and 69 guests
