Fixing centres dimension for front plate mount
4.2 V8 32v FSI - 444 bhp
noidea
Post by noidea » Fri Apr 21, 2017 9:32 am
Not sure if anyone can help?
I need the centre distance between the two fixings for the front number plate plinth. (B8 RS4 grille)
I am going to make my own front plate plinth to suit my 5 digit number plate and i have stuck my existing plate on with lots of sticky pads and it would be a pain to have to remove it just to measure the fixing centres.
RS4B8LYF
Re: Fixing centres dimension for front plate mount
Post by RS4B8LYF » Fri Apr 21, 2017 10:55 am
? Are you not going to need to remove in any case to fit plinth first?
:kissmyrings:
ARSEY4
Post by ARSEY4 » Fri Apr 21, 2017 3:13 pm
You don't really need a plinth. I took the existing plinth off, offered it up to the shorter number plate and marked the holes then used the existing holes that the old plinth fitted to attach the shorter plate. Took 10 minutes.
noidea
Post by noidea » Fri Apr 21, 2017 8:47 pm
RS4B8LYF wrote:? Are you not going to need to remove in any case to fit plinth first?
I am going to machine a new one and shorten another plate first. I need to do myself a drawing and it would save having to tackle all the sticky pads twice.
Once everything is machined i will them fit.
Sent from my Nexus 6P using Tapatalk
noidea
Post by noidea » Fri Apr 21, 2017 8:49 pm
I don't want any screws through the plate, I prefer to use sticky pads.
Could you do a quick measure for me of the screws please?
RS4B8LYF
Post by RS4B8LYF » Sat Apr 22, 2017 11:54 am
I'm thinking of screwing a decent size magnet to each fixing point on bar (magnet should be discreet enough) then gluing two suitable metal washers to back of pressed plate. Makes an easy remove and ride option ? Will post once done if my theory works
:kissmyrings:
