Could not resist
Re: Could not resist
You trailering your French shopping trolley to the track then? I see you binned the seatbelts - would need those for an MOT.
You should install one of those £1 key chain slots on the back just for jokes!
2007 RS4 B7 Avant
I think the dry ice sort of freezes the sound proofing making it brittle so it sort of cracks as you scrape it. Personally I would have saved the money and just used a hot air gun. Same job different technique. Mental man likes it the cold way. Lmfyao.
Current ride’s
Previous rides
Previous rides
I'm having one of those "LOL" moments.
Current ride’s
Previous rides
Previous rides
Correct! But its way way easier this way!!! Freeze, wait 10min, bash with small hammer and it comes of like caramel. Scraping is labour intensive. Dry ice is cheap. £28 for 10kg bagEddie555 wrote:I think the dry ice sort of freezes the sound proofing making it brittle so it sort of cracks as you scrape it. Personally I would have saved the money and just used a hot air gun. Same job different technique. Mental man likes it the cold way. Lmfyao.
RS4 B7 aka Vinnie
RS4 B7 aka Vinnie
It will have permanent 5point harness.FaisalJ wrote:You trailering your French shopping trolley to the track then? I see you binned the seatbelts - would need those for an MOT.
Don't think you need standard belts for MOT. Could be wrong.
RS4 B7 aka Vinnie
RS4 B7 aka Vinnie
Harnesses are OK for MOTpule333 wrote:It will have permanent 5point harness.FaisalJ wrote:You trailering your French shopping trolley to the track then? I see you binned the seatbelts - would need those for an MOT.
Current : 2016 Audi SQ7
| Radical SR3 Supersport
| Ultima Evolution
Ha ha thanks Phil!PhilT wrote:Harnesses are OK for MOTpule333 wrote:It will have permanent 5point harness.FaisalJ wrote:You trailering your French shopping trolley to the track then? I see you binned the seatbelts - would need those for an MOT.
I was just googling that..
RS4 B7 aka Vinnie
RS4 B7 aka Vinnie
You could have brought a 10kg case of chicken breasts off me for that and fed the family a 2 weeks.
Current ride’s
Previous rides
Previous rides
I stand corrected!pule333 wrote:Ha ha thanks Phil!PhilT wrote:Harnesses are OK for MOTpule333 wrote: It will have permanent 5point harness.
2007 RS4 B7 Avant
Here's a pretty good shopping list (Prices may have changed):
Brakes
£250.00 - Brembo High Carbon (HC) Brake Discs & Ferodo Racing DS1.11 Brake Pads - Front (George @ http://www.roadtrackraceparts.com/)
£40.46 - Motul RBF 660 Factory Line Racing Fully Synthetic DOT 4 Brake Fluid 3 X 500ml
£134.92 - Renault Clio 2.0 (01-03) Front Brake Calipers (Ours had seen better days and you need good brakes)
£23.95 - RENAULT CLIO MK2 2x FRONT BRAKE CALIPER SLIDER PIN KITS (VENTED DISC) BCF1310AX2
Insurance and Road Tax
£365.00 - Track car insurance with CCI
£270 - Road Tax 12 Months
Track Stuff
£3.99 - Green Tow Strap (MSA Spec)
£2.50 - M16 bolt (Tow Strap)
£80.00 - Used Harnesses
£63.37 - OMP HUB BOSS KIT OD/1960RE114A
£59.94 - Steering Wheel (http://www.ebay.co.uk/itm/401039742519)
£550.00 - Two SABELT GT-090 RACER DUO FIA MOTORSPORT SEATSeats + OMP - RENAULT CLIO 2ND SERIES DIRECT FIT SUBFRAMES + Sliding Runners (GSM Performance)
£1.56 - 3.9 ohm 0.6W resistors for the airbags
£17.99 - EIBACH Front Camber Bolts
£610.98 - Bilstein B14 Coilover Full Kit Height Adjustable 47-087750 (Depending on your budget, you might want to go with coilovers for the rear. The B14 kit is OK but there's better stuff out there)
£104.12 - Gulf Competition 5w-40 Racing Ester Fully Synthetic Engine Oil (5w40) -2 X 5 litres and Fuchs TITAN SINTOFLUID SAE 75W-80 synthetic manual transmission fluid -4 X 1 Litre (Opie Oils - Site Sponsor
£10.80 - WD-40 Contant Cleaner 400ml (Because it's French and it doesn't like water)
Wheels and Tyres
Team Dynamics 1.2
Tyres Federal 595RSR (We're moving to these next)
Brakes
Track Stuff
Wheels and Tyres
Team Dynamics 1.2
| Ultima Evolution
Additional useful info:
Renault Built-in Diagnostic
With the ignition off press and keep hold of the button at the end of the stalk and turn the ignition on. All the dashboard warning lights will come on and the speedo and rev counter will go through a predefined sequence.
Every time you press the stalk button the digital readout will show information (listed below) each time you press the button some more information will show.
- All the lights lit (shows if you have a failed LED).
- The amount of fuel left in the tank in litres.
- Fuel flow (the engine has to be running. This is in litres per hour)
- Stored faults
t = an injection fault has been detected for a minimum of 4 seconds
J = a fault has been noted on the fuel gauge. It must have disconnected for longer than 100 seconds. The resistance from the fuel tank sensor needs to be between 5 and 350 Ohms.
d = an injection signal fault has been detected
h = an oil level sensor fault has been detected. Resistance from the sensor should be between 6 and 20 Ohms. Any reading over 20Ohms is an open cicuit anything under 3 is a short circuit.
If no faults are logged then dashes will show fixed dashes. Press the reset/trip button to clear the logged faults. Other faults aren't shown on the display.
To stop it turn the engine off or move the key to the off position.
Servicing
Engine oil - 5 litres - 5w40
Gearbox oil - 3.1 litres - 75w80
Geo setting
Front
-2.7 camber
10min toe OUT
Castor standard (fixed)
Rear
-2.5 camber (add -1 shim)
Standard toe (18min toe in iirc) for safer handling
Suspension (This is work in progress on ours as we need to get all the geo done)
Right higher than left to compensate for driver - Front r595 l585 / Rear r594 l597
Rake 30mm front / 45mm rear
This might save you a bit of searching but as always, it's each to their own on these things.
- Stored faults
Servicing
Geo setting
Front
-2.7 camber
10min toe OUT
Rear
| Ultima Evolution
OMG Phil!!! Thank you so much for this!!! This info is priceless
RS4 B7 aka Vinnie
RS4 B7 aka Vinnie
The difference between Men and Boys are the cost of their toys.
Ps: Always be careful of the Masters teachings. He will never teach you everything just in case you beat him.
Current ride’s
Previous rides
Previous rides
Full roll cage going in
RS4 B7 aka Vinnie
RS4 B7 aka Vinnie
Nice!
Is that JC Weldfab?
Is that JC Weldfab?
2007 RS4 B7 Avant
Users browsing this forum: No registered users and 147 guests
