Understeer....
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
S4INT
Understeer....
Post by S4INT » Sun Sep 18, 2005 8:28 pm
Does anyone have any tips for reducing understeer?
My S4 Avant has already got H&R coil-overs, but under moderate to hard cornering it seems to understeer quite early. Is this what the S4 does when it's pushed or is it just mine? Wondering whether my tyres are past their best or perhaps I need to uprate something else? (RS4 ARB's?)
My other car is a BMW 330 Sport and the handling on standard suspension is far better resolved than the Audi, with little understeer unless you are really pushing it.
Any advice/tips welcome!
Golf R - with added MRC
Sprint blue B7 RS4 Avant - Sold
Ultimate Silver Nissan GT-R - Sold
Avus MRC 470 B5 RS4 Avant - Sold
jeffw
RE: Understeer....
Post by jeffw » Sun Sep 18, 2005 8:46 pm
What tyres are you running ?
S4INT
Post by S4INT » Sun Sep 18, 2005 8:50 pm
Michelin Pilots - I'm on RS4 replicas so 225/40/18's.
Dippy
Post by Dippy » Mon Sep 19, 2005 3:12 am
My H&R's give me a bit of oversteer at low and medium speeds, and I only get understeer when really pushing hard. Have you had your alignment checked?
2001 Silver S4 Avant
kies4
Post by kies4 » Mon Sep 19, 2005 6:35 am
I'm no expert but i thought a more rigid anti roll bar on the back would solve this problem.
S4 Crazy Horse. Ringsticker & MRC black magic.
Nige_RS4
Post by Nige_RS4 » Mon Sep 19, 2005 8:56 am
The H&R ARB's will sort most of your problems out, unless you go in too fast, then you have to expect a bit of understeer. My car used to push wide at slow to medium speeds on tight roundabouts, but it's great now, actually better than my BMW!
BRETTCOLLINS
Post by BRETTCOLLINS » Mon Sep 19, 2005 10:30 am
The H&R ARB's did sort my problems out. handling is much better thank you.
MING BLUE AUDI S4
Car is on Lock down
506.9 BHP @ 6.020 RPM
445.0 WHP @ 5.981 RPM
481.5 IBFT @ 4.976 RPM
don
Post by don » Mon Sep 19, 2005 11:59 am
An H&R fat anti-roll bar upgrade is definitely the go.
http://www.rs246.com/index.php?name=PNp ... 8&start=30
S4INT
Post by S4INT » Mon Sep 19, 2005 12:38 pm
Thanks for the info guys - looks like the H&R ARB's are the way to go.
Haven't had my alignment checked, so maybe that would be the first port of call, and my steering wheel is slightly off to the right so would be a good opportunity to get that sorted as well.
dazzer
Post by dazzer » Mon Sep 19, 2005 7:42 pm
Please let me know what caused your steering wheel to be off to the right, I have got the same on mine.
cpufreak
Post by cpufreak » Tue Sep 20, 2005 12:28 am
dazzer - getting your tracking sorted should fix that.
tartan_rob
Post by tartan_rob » Tue Sep 20, 2005 8:59 am
Get tracking done by some with laser equipment that knows what they are doing.
2017 Kawasaki Z1000
2014 RS6
2014 S1
fade2grey
Post by fade2grey » Tue Sep 20, 2005 10:46 am
you can reduce understeer buy reducing grip at the back end, either by tightening it (a-la anti roll bar), tyres/pressures/alignment..
or slow in, fast out in the corners...
98/Missano/Bose/Carbon
DavidT
Post by DavidT » Tue Sep 20, 2005 11:13 am
I agree, driving style is the biggest factor by far, regardless of what suspension setup you have. You can only really practice that on a racing circuit, lap after lap. A datalogger would help too.
The other thing to consider is that the more you move from understeer through a neutral balance into oversteer, the more nervous and 'pointy' a car becomes. Fine for the track when you have little or nothing else to worry about and are close to the limit, but not what you want for an emergency situation on the public roads, which is why car manufacturers design understeer in.
The 4wd Audi's understeer for sure, but driving a quick front wheel drive car recently was a real wake up call for me :-( and :-)
eddiecrawford
Post by eddiecrawford » Tue Sep 20, 2005 8:36 pm
if you are a woose like me and only really provoke the car into under/oversteer in the wet, then the cheap option is wait until your front tyres are a mm or 2 more worn on the front than the back then swap them (as above, just reducing grip at the rear)
easy to make it neutral, when you are thinking of getting new tyres soon, if you know what i mean.... :)
Users browsing this forum: Google Adsense [Bot] and 86 guests
