Understeer....
Understeer....
Does anyone have any tips for reducing understeer?
My S4 Avant has already got H&R coil-overs, but under moderate to hard cornering it seems to understeer quite early. Is this what the S4 does when it's pushed or is it just mine? Wondering whether my tyres are past their best or perhaps I need to uprate something else? (RS4 ARB's?)
My other car is a BMW 330 Sport and the handling on standard suspension is far better resolved than the Audi, with little understeer unless you are really pushing it.
Any advice/tips welcome!
Golf R - with added MRC
Sprint blue B7 RS4 Avant - Sold
Ultimate Silver Nissan GT-R - Sold
Avus MRC 470 B5 RS4 Avant - Sold
RE: Understeer....
What tyres are you running ?
My H&R's give me a bit of oversteer at low and medium speeds, and I only get understeer when really pushing hard. Have you had your alignment checked?
2001 Silver S4 Avant
- 5th Gear
An H&R fat anti-roll bar upgrade is definitely the go.
http://www.rs246.com/index.php?name=PNp ... 8&start=30
Thanks for the info guys - looks like the H&R ARB's are the way to go.
Haven't had my alignment checked, so maybe that would be the first port of call, and my steering wheel is slightly off to the right so would be a good opportunity to get that sorted as well.
I agree, driving style is the biggest factor by far, regardless of what suspension setup you have. You can only really practice that on a racing circuit, lap after lap. A datalogger would help too.
The other thing to consider is that the more you move from understeer through a neutral balance into oversteer, the more nervous and 'pointy' a car becomes. Fine for the track when you have little or nothing else to worry about and are close to the limit, but not what you want for an emergency situation on the public roads, which is why car manufacturers design understeer in.
The 4wd Audi's understeer for sure, but driving a quick front wheel drive car recently was a real wake up call for me
and
if you are a woose like me and only really provoke the car into under/oversteer in the wet, then the cheap option is wait until your front tyres are a mm or 2 more worn on the front than the back then swap them (as above, just reducing grip at the rear)
easy to make it neutral, when you are thinking of getting new tyres soon, if you know what i mean....
