Towbar
Re: Towbar
Yes.
Re: Towbar
Is it not an issue depending on what suspension you're running?
Thought i'd read on here that if you're on Air then you can't but regular setup you can (could have been the other way round).
Paul
05 Blue DMS E60 M5 (Sold)
14 Grey LCi F10 M5 (Rejected)
Re: Towbar
Yes, must be on air and not have carbon pack.
- Shinobi675
- 5th Gear
Re: Towbar
Would it be a straight (ignoring legalities!) swap from the one installed on air to a drc car? Or is it a physical difference as well as the type approval?
Re: Towbar
I'm pretty sure it's not mechanically possible.
Re: Towbar
I believe the air was required to self level the car with the extra load. Not sure if the mounting points are still there or not on a DRC car. Edit: doddle just replied above.
The bit about carbon is purely because the carbon rear diffuser is a single piece of carbon with no flap to open to allow the toe bar to swing out like it can on the plastic diffuser which has a flap.
Re: Towbar
The factory bar occupies a void that contains DRC components on DRC cars. That is why you have to specify air if you want the tow bar. Self-levelling is a bonus rather than the reason.
jipettersen
- 1st Gear
Re: Towbar
Agree 100% Air is a bonus. Possible to adjust ride height, same level on fylly loaded car. This is not a track car so why spend money on DRC?
Re: Towbar
Don't start that debate again!!
Re: Towbar
It's not a boat so why pay all that money for a car that rolls like one?jipettersen wrote:Agree 100% Air is a bonus. Possible to adjust ride height, same level on fylly loaded car. This is not a track car so why spend money on DRC?
Re: Towbar
Too late...doodlebug wrote:Don't start that debate again!!
Re: Towbar
Snigger.
Re: Towbar
Thanks all.
So can't get one with sports pack or exterior carbon? Car has to have the air suspension- correct?
And there doesn't appear to be many like this ....
Users browsing this forum: No registered users and 55 guests
