Rear caliper plates ??
skirs6
Post by skirs6 » Sun Jan 15, 2017 12:12 am
I had these on my C6 which involved drilling 10mm holes in the caliper. I see some C7's have these. Mine doesn't. Is it just on FL or is it an option ??
Re: Rear caliper plates ??
Post by MikeFish » Sun Jan 15, 2017 12:58 am
It was standard on the facelift. I don't think it was an option on pre facelift. I'd imagine you can retrofit but note sure if the holes need to be drilled
A20LEE
Post by A20LEE » Sun Jan 15, 2017 8:46 am
skirs6 wrote:I had these on my C6 which involved drilling 10mm holes in the caliper. I see some C7's have these. Mine doesn't. Is it just on FL or is it an option ??
Which model are the ones you fitted to the C6 from? Was searching the forum for info on this model but couldnt find it
wildbore
Post by wildbore » Sun Jan 15, 2017 9:21 am
MikeFish wrote:It was standard on the facelift. I don't think it was an option on pre facelift. I'd imagine you can retrofit but note sure if the holes need to be drilled
Is this thread referring to the fill-in plates that make the rear floating calipers look a little like four-pot calipers? If so, that plate is not standard on the facelift. I *think* that the plate was fitted on cars where the red front calipers were ordered.
skirs6
Post by skirs6 » Sun Jan 15, 2017 9:37 am
Yes that's the ones. I drilled the holes to fit them on my C6 . They really finish off the rear calipers nicely. I can't imagine Audi would make a completely different caliper for the rear one for red and others for black.
It was Chris off here that put me onto it I will message him later.
wildbore
Post by wildbore » Sun Jan 15, 2017 10:13 am
I wasn't implying that the caliper is different if it's red. Just that, if you ordered the optional red finish to the front calipers, they also fitted a red-coloured fill-in plate to the rear calipers as part of that option. The rear and front calipers are, of course, the same in both finishes.
Post by MikeFish » Sun Jan 15, 2017 10:54 am
I thought they were standard on all facelift cars. I have the plates on my black calipers.
Post by MikeFish » Sun Jan 15, 2017 10:59 am
Eddie555
Post by Eddie555 » Sun Jan 15, 2017 11:19 am
They were part of the my2016 facelifted facelift. When they did the alcantra door inserts as well.
Current ride’s
Previous rides
RS6chris!
Post by RS6chris! » Sun Jan 15, 2017 11:54 am
Have PMd you mate
I retro fitted to both my C6 and C7
Pretty easy to be fair.
RS6 C8 carbon black(merlin)
Panamera Turbo S e hybrid
RS6 C8 launch edition
R8 V10 plus
C7 RS6 PE dynamic pack plus
C7 RS6
Porsche Panamera Turbo
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW Passat 130d 4 motion
VW bora 150pd
Ford Mondeo Ghia X V6
Ford Focus zetec
Rover 214!!
RS6chris!
Post by RS6chris! » Sun Jan 15, 2017 12:06 pm
Another thing
You can't buy the little metal clips separate either.
So if you loose one you've got to buy full caliper set again(X1) and they ain't cheap.
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
skirs6
Post by skirs6 » Sun Jan 15, 2017 1:33 pm
Thanks for all the advice unfortunately mine is not a FL car. ( sad face ) might be 10mm drill time again
