Rear caliper plates ??
I had these on my C6 which involved drilling 10mm holes in the caliper. I see some C7's have these. Mine doesn't. Is it just on FL or is it an option ??
Re: Rear caliper plates ??
It was standard on the facelift. I don't think it was an option on pre facelift. I'd imagine you can retrofit but note sure if the holes need to be drilled
Which model are the ones you fitted to the C6 from? Was searching the forum for info on this model but couldnt find itskirs6 wrote:I had these on my C6 which involved drilling 10mm holes in the caliper. I see some C7's have these. Mine doesn't. Is it just on FL or is it an option ??
Is this thread referring to the fill-in plates that make the rear floating calipers look a little like four-pot calipers? If so, that plate is not standard on the facelift. I *think* that the plate was fitted on cars where the red front calipers were ordered.MikeFish wrote:It was standard on the facelift. I don't think it was an option on pre facelift. I'd imagine you can retrofit but note sure if the holes need to be drilled
wildbore wrote:Is this thread referring to the fill-in plates that make the rear floating calipers look a little like four-pot calipers? If so, that plate is not standard on the facelift. I *think* that the plate was fitted on cars where the red front calipers were ordered.MikeFish wrote:It was standard on the facelift. I don't think it was an option on pre facelift. I'd imagine you can retrofit but note sure if the holes need to be drilled
Yes that's the ones. I drilled the holes to fit them on my C6 . They really finish off the rear calipers nicely. I can't imagine Audi would make a completely different caliper for the rear one for red and others for black.
It was Chris off here that put me onto it I will message him later.
I wasn't implying that the caliper is different if it's red. Just that, if you ordered the optional red finish to the front calipers, they also fitted a red-coloured fill-in plate to the rear calipers as part of that option. The rear and front calipers are, of course, the same in both finishes.
I thought they were standard on all facelift cars. I have the plates on my black calipers.
They were part of the my2016 facelifted facelift. When they did the alcantra door inserts as well.
Current ride’s
Previous rides
Previous rides
Have PMd you mate
I retro fitted to both my C6 and C7
Pretty easy to be fair.
RS6 C8 carbon black(merlin)
Panamera Turbo S e hybrid
RS6 C8 launch edition
R8 V10 plus
C7 RS6 PE dynamic pack plus
C7 RS6
Porsche Panamera Turbo
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW Passat 130d 4 motion
VW bora 150pd
Ford Mondeo Ghia X V6
Ford Focus zetec
Rover 214!!
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
Another thing
You can't buy the little metal clips separate either.
So if you loose one you've got to buy full caliper set again(X1) and they ain't cheap.
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
Thanks for all the advice unfortunately mine is not a FL car. ( sad face ) might be 10mm drill time again
Users browsing this forum: No registered users and 55 guests
