Going from auto to paddles and keeping with paddles
5.0 V10 50v biturbo - 571 bhp
Shaneyboi88
Post by Shaneyboi88 » Tue Oct 18, 2016 9:58 pm
Ive test drove some rs6 and looking to buy one. When ive changed from auto to manual (paddles) if im not chaging gear frequent enough it goes bk to auto. Is there any way to stop this so if i want it just stays with the paddles ? Thanks
Jim Haseltine
Re: Going from auto to paddles and keeping with paddles
Post by Jim Haseltine » Tue Oct 18, 2016 11:03 pm
Not that I know of (although I'm happy to be corrected) - as I understand things, the standard software is set to revert to auto mode if you haven't changed gear again after a period (20secs?) and will override your request to change up if the revs are too low or to change down if the revs are too high. It'll also change up for you if the revs are too high when you're changing manually.
Having said that, 30+ years experience in software development and support says that your results may vary from mine.
Post by MikeFish » Tue Oct 18, 2016 11:58 pm
Don't you move the gear lever to the left to put it into full manual mode that doesn't go back to drive?
Shaneyboi88
Post by Shaneyboi88 » Wed Oct 19, 2016 12:14 am
Im not sure ill give it a try and find out thanks
AdrianE
Post by AdrianE » Wed Oct 19, 2016 7:39 am
Correct - if it's in D and you use paddles it'll revert after set time with no paddle use. To keep it in manual you need to knock the lever across. Whenever I drive one, if I override the gears with the paddles and then want to revert to D I just knock it over to manual and straight back into D.
S will sharpen throttle response and make it hold onto gears for longer, but is still an auto mode, plus you can't knock it across into manual without going back into D first
2011 S5 Sportback in Phantom Black with black leather, 9x20 7 spokes, tech pack high, phone prep high, adaptive xenon plus, intelligent key, memory seats pack, sunroof, B&O, Audi Drive Select & quattro Sports Diff, cruise, DAB, parking system plus, storage pack, through load
===SOLD=== 2002 S8 4.2 Final Edition in Avus Silver with mauve (purple!) leather, 8.5x20 9 spokes, bi-xenons, 10 way electric Recaros, added RNS-E, hybrid TV and bluetooth goodness - and a Milltek ===SOLD===
doodlebug
Post by doodlebug » Wed Oct 19, 2016 8:02 am
Worth noting that C6 will not bounce on the limiter in manual, it'll change up.
kent_andy
Post by kent_andy » Wed Oct 19, 2016 8:27 am
Yes, has to be in M to stay on the paddles. Never used to use the paddles until I had the gearbox remap, it raises the limiter and now you can shift between gears better whereas before it just used to go through gears far too quickly there was no way I could of been quicker, that was a MTM map with no gearbox software tho
2017 911 991.2 Turbo S
2007 Audi A3 2.0T Quattro
Users browsing this forum: Google Adsense [Bot] and 128 guests
