Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
MrHilario
- 5th Gear
Post
by MrHilario » Fri Sep 16, 2016 2:46 pm
longman h wrote:Another VCDS owner and I'm based in Orpington, so if you need some help, let me know.
Hey Longman, I am in Dartford and need my Tyre Pressure Sensors disabled as one doesn't work and the warning keeps flashing up. Would you be able to help me out at all? Will come to you if you can. Cheers
1.4 Fiesta (Silver)
2.8 VW Bora V6 4motion (Blue)
4.2 Audi RS4 B7 Avant (Black)
Mav8
Post
by Mav8 » Fri Sep 16, 2016 2:53 pm
B5 owner with
Vagcom in Herts
Mav8
RS3- Sepang
Gone
F80-M3
B7-RS4
B5-RS4
Post
by bam_bam » Fri Sep 16, 2016 2:54 pm
MrHilario wrote:longman h wrote:Another VCDS owner and I'm based in Orpington, so if you need some help, let me know.
You can just disable them on the DIS.
MrHilario
- 5th Gear
Post
by MrHilario » Fri Sep 16, 2016 2:57 pm
bam_bam wrote:MrHilario wrote:longman h wrote:Another VCDS owner and I'm based in Orpington, so if you need some help, let me know.
How do I do that? I've tried but can only seem to store the pressures? Then it goes off again
1.4 Fiesta (Silver)
mikep99
Post
by mikep99 » Fri Sep 16, 2016 3:32 pm
@MrHilario - have a look here -
viewtopic.php?f=35&t=89343&start=15
Basically, in
VCDS you do:
Select -> 17-Instruments -> Adaptation -> Channel 61.
Subtract 512 from whatever value you find there.
The instuments will then not show any TPMS errors etc.
Did this on mine a while ago with no problems.
Ta
Mike
rspj
Post
by rspj » Fri Sep 16, 2016 5:59 pm
I have got one a few weeks back I can bring to ADI in October if you wish i may need a bit of help using it only used once sure be someone help us[WHITE SMILING FACE]
rs4 b8 Suzuka, grey 14
longman h
Post
by longman h » Sat Sep 17, 2016 10:00 pm
Feel free to pop round one night next week if you want. Pm me and I'll send you my address.
Daytona Grey C6 RS6 Avant
Ebony Black C5 RS6 Plus - Gone
MrHilario
- 5th Gear
Post
by MrHilario » Mon Sep 19, 2016 8:35 am
mikep99 wrote:@MrHilario - have a look here -
Basically, in VCDS you do:
Ta
Mike
Thanks Mike, I don't actually have a Vagcom but this will help when I get hold of one.
1.4 Fiesta (Silver)
MrHilario
- 5th Gear
Post
by MrHilario » Mon Sep 19, 2016 8:38 am
rspj wrote:
I have got one a few weeks back I can bring to ADI in October if you wish i may need a bit of help using it only used once sure be someone help us [WHITE SMILING FACE]
Cheers Paul but I cant make ADI, I have a family 50th to attend
1.4 Fiesta (Silver)
MrHilario
- 5th Gear
Post
by MrHilario » Mon Sep 19, 2016 8:39 am
Thanks Longman, I'll send you a PM.
1.4 Fiesta (Silver)
jonytek
- 5th Gear
Post
by jonytek » Wed Sep 21, 2016 8:20 pm
Simon I have borrowed one off a forum member so I should have it over the weekend so I'm happy to help out also..
MrHilario
- 5th Gear
Post
by MrHilario » Fri Oct 07, 2016 7:54 am
Thanks again for your help last night Longman, much appreciated!
And i've just realised why your username is Longman! You are one of the tallest blokes I've ever met!
1.4 Fiesta (Silver)
MrHilario
- 5th Gear
Post
by MrHilario » Fri Oct 07, 2016 8:48 am
Ta
Mike
Also, thanks for this Mike, very helpful and got the job done in 5 mins! Cheers
1.4 Fiesta (Silver)
mikep99
Post
by mikep99 » Fri Oct 07, 2016 11:38 am
No probs
Bizarre thing - had my battery disconnected the other day and after reconnecting and scanning, no TPMS warnings.
I'll give it another scan after its been driven for a bit and see if anything pops up..
I like having a 'clean' dashboard so all is good.
Mike
FrazerD
Post
by FrazerD » Thu Sep 27, 2018 7:02 pm
Hi folks,
Before I go and buy
VCDS ir obdeleven, I am curious to know what options I have for coding on my B7? And if there is anyone close to me (Ipswich ish) that has
VCDS or obdeleven that would maybe do some coding.
