Hey Longman, I am in Dartford and need my Tyre Pressure Sensors disabled as one doesn't work and the warning keeps flashing up. Would you be able to help me out at all? Will come to you if you can. Cheerslongman h wrote:Another VCDS owner and I'm based in Orpington, so if you need some help, let me know.
VAG COM Owners Register
Re: VAG COM Owners Register
1.4 Fiesta (Silver)
2.8 VW Bora V6 4motion (Blue)
4.2 Audi RS4 B7 Avant (Black)
1.4 Fiesta (Silver)
B5 owner with Vagcom in Herts
Mav8
Mav8
RS3- Sepang
Gone
F80-M3
B7-RS4
B5-RS4
Gone
F80-M3
B7-RS4
B5-RS4
You can just disable them on the DIS.MrHilario wrote:Hey Longman, I am in Dartford and need my Tyre Pressure Sensors disabled as one doesn't work and the warning keeps flashing up. Would you be able to help me out at all? Will come to you if you can. Cheerslongman h wrote:Another VCDS owner and I'm based in Orpington, so if you need some help, let me know.
How do I do that? I've tried but can only seem to store the pressures? Then it goes off againbam_bam wrote:You can just disable them on the DIS.MrHilario wrote:Hey Longman, I am in Dartford and need my Tyre Pressure Sensors disabled as one doesn't work and the warning keeps flashing up. Would you be able to help me out at all? Will come to you if you can. Cheerslongman h wrote:Another VCDS owner and I'm based in Orpington, so if you need some help, let me know.
1.4 Fiesta (Silver)
1.4 Fiesta (Silver)
@MrHilario - have a look here - viewtopic.php?f=35&t=89343&start=15
Basically, in VCDS you do:
Select -> 17-Instruments -> Adaptation -> Channel 61.
Subtract 512 from whatever value you find there.
The instuments will then not show any TPMS errors etc.
Did this on mine a while ago with no problems.
Ta
Mike
Ta
Mike
I have got one a few weeks back I can bring to ADI in October if you wish i may need a bit of help using it only used once sure be someone help us[WHITE SMILING FACE]MrHilario wrote:How do I do that? I've tried but can only seem to store the pressures? Then it goes off againbam_bam wrote:You can just disable them on the DIS.MrHilario wrote: Hey Longman, I am in Dartford and need my Tyre Pressure Sensors disabled as one doesn't work and the warning keeps flashing up. Would you be able to help me out at all? Will come to you if you can. Cheers
rs4 b8 Suzuka, grey 14
Feel free to pop round one night next week if you want. Pm me and I'll send you my address.MrHilario wrote:How do I do that? I've tried but can only seem to store the pressures? Then it goes off againbam_bam wrote:You can just disable them on the DIS.MrHilario wrote: Hey Longman, I am in Dartford and need my Tyre Pressure Sensors disabled as one doesn't work and the warning keeps flashing up. Would you be able to help me out at all? Will come to you if you can. Cheers
Daytona Grey C6 RS6 Avant
Ebony Black C5 RS6 Plus - Gone
Thanks Mike, I don't actually have a Vagcom but this will help when I get hold of one.mikep99 wrote:@MrHilario - have a look here - viewtopic.php?f=35&t=89343&start=15
Ta
Mike
1.4 Fiesta (Silver)
1.4 Fiesta (Silver)
Cheers Paul but I cant make ADI, I have a family 50th to attendrspj wrote: I have got one a few weeks back I can bring to ADI in October if you wish i may need a bit of help using it only used once sure be someone help us [WHITE SMILING FACE]
1.4 Fiesta (Silver)
1.4 Fiesta (Silver)
1.4 Fiesta (Silver)
1.4 Fiesta (Silver)
Simon I have borrowed one off a forum member so I should have it over the weekend so I'm happy to help out also..
Thanks again for your help last night Longman, much appreciated!MrHilario wrote:longman h wrote:
And i've just realised why your username is Longman! You are one of the tallest blokes I've ever met!
1.4 Fiesta (Silver)
1.4 Fiesta (Silver)
Also, thanks for this Mike, very helpful and got the job done in 5 mins! Cheersmikep99 wrote:@MrHilario - have a look here - viewtopic.php?f=35&t=89343&start=15
Ta
Mike
1.4 Fiesta (Silver)
1.4 Fiesta (Silver)
No probs
Bizarre thing - had my battery disconnected the other day and after reconnecting and scanning, no TPMS warnings.
I'll give it another scan after its been driven for a bit and see if anything pops up..
I like having a 'clean' dashboard so all is good.
Mike
Mike
