I'm confused about the suspension options for the RS6 Performance, perhaps someone can enlighten/correct me...
The standard suspension (non dynamic) is air suspension? Does it adjust ride height based on what setting it is in? Or is there only 1 suspension setting?
Is it correct to assume that pretty much everyone goes for the Dynamic suspension? And is it this also air ride (height adjustable etc)
When it comes to lowering I have heard that some people go for springs and others have to lower it through Vagcom, is this correct? And finally whats the deal with the airmatic lowering links? http://www.ebay.com.au/itm/AUDI-A6-S6-R ... SwajVUSUPh
Thx in advance!
So whats the deal with suspensions?
Re: So whats the deal with suspensions?
Yes it is adjusting ride height depending if you are in comfort or dynamic for example.
However you do not have the same handle as you get with the DRC from what ive heard.
Dynamic suspension is not air. And it is not adjustable (Without changing springs or getting adjustable springs that is)
If you get the DRC (Dynamic suspension) you have to change the springs to lower it (20 - 40 mm is normal)
If you get the air version (None dynamic) you can connect to the car with a VCDS-cable and change the car (Normally maximum 17mm)
If you want to have a controll unit inside the car who lets you set the ride height (More then the none dynamic version) you have too buy a unit like the one you linked
Hope it helps!
//Rasmus
Hope it helps!
//Rasmus
Audi RS6 Misano build viewtopic.php?f=121&t=122026
Audi RS6 Misano & Audi R8 White Pictures https://postimg.org/gallery/19xrelsxq/
Yeah, what he said.
There has been much debate as to whether air or springs are the better option. Some say air is great and perfect for their needs, others not.
If you drive like an absolute hooligan, the road is a bit gnarly and you're cornering "with haste" air suspension can on a rare occasion feel a bit undulating.
I don't often drive like a hooligan so I've only experienced this circa 10 times in 6k miles. For me, its a small price to pay to turn the car into a softly sprung limo when I'm transporting the in-laws or when I need to jack the ride height up if I'm boarding a ferry/steep car park ramp/ farcically oversized speed hump side street.
You can independently raise or lower the car with a separate button regardless of what DRC setting you are in.
Dynamic
Dropped mine 15mm
Spacered it
It actually drives better....far less bounce from wheels on rebound...if that makes sense?
Actually rides better too.
Of course most people will stick with OEM but honestly my car feels Better to me modded.
Il await "audi spends millions on development ". .. what do I know? I'm only speaking from personal experience.
Car is a better package now.
Dropped mine 15mm
Spacered it
RS6 C8 carbon black(merlin)
Panamera Turbo S e hybrid
RS6 C8 launch edition
R8 V10 plus
C7 RS6 PE dynamic pack plus
C7 RS6
Porsche Panamera Turbo
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW Passat 130d 4 motion
VW bora 150pd
Ford Mondeo Ghia X V6
Ford Focus zetec
Rover 214!!
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
This. Except I dropped mine 40mm. Clearly this would be too low for Audi to sell as a mass produced car.RS6chris! wrote:Dynamic
Dropped mine 15mm
Spacered it
I get the benefits of air (adjustable ride height in-car) and love the thought of it but I just found it too rolly on roundabouts. And DRC on comfort is plenty soft enough for me.
Thanks for all the help guys, I have a much clearer idea of it all now
