5k kick with stage 2?
Should I be feeling a kick at 5k with an MRC stage 2?
Looking at the dyno graph there seems to be a decent increase at around that spot. Is the kick from the secondary flap in the airbox or from the map/ecu. Do people with CAI and flap delete still get the kick?
Mines going up to MRC on Monday to have a look at it so I'm trying to give them as much info as I can on the car as I'm sure there's an intermittent problem somewhere.
Re: 5k kick with stage 2?
No one?
the flap on the airbox has nothing to do with the so called kick
yes i do still get the kick with it all removed
mrc will know what theyre on about so no need to worry
Im sure they'll get to the bottom of it, I'm just trying to give them as much info as i can.
Pretty sure theres no vac leak as I've tested it as best i can. I was thinking maybe the solenoid on the airbox may of had a intermittent fault due to no 5k kick, that was the thinking behind the question. I did the Arthur test on a couple of occasions, 1st time i was getting 8.4-8.5 times, that was early morning and quite cool. Next i did a run on the same road each way and it was hot, around 27* and got 7.8 both times. The car feels faster some times than others...
Sounds like plain old heat soak?
No i don't think so, both times the car was driven there on a dual carriage way and was not sat around or hammered before the test, also the hot day produced the faster times..MikeFish wrote:Sounds like plain old heat soak?
The kick is still there on mine with MRC stage 2, CAF and flap removed etc...
Hope you get to the bottom of it, mine feels like a new car since coming back from MRC, totally different animal.
B7 RS4 - Sprint Blue Saloon
MRC Stg2 map : Pre-cat delete : MRC Stg2 Inlet : CAF : 437PS/462Nm
Int. & Ext. LED's : KW V3's : H&R Spacers 8mm
Well... It does. It's well reported online? My solenoid went so the flap didn't activate at 5k... So I didn't get a kick... Solenoid now replaced and working and the kick is back.Rick_RS4 wrote:the flap on the airbox has nothing to do with the so called kick
It lets in more air... =bigger bang... =more power...=kick...
Toy: '07 B7 RS4 Avant Sprint Blue
Daily: 06 B7 2.0T Special Edition Avant
Previous: '09 B8 2.0T Quattro S line Avant
- OEM Defined - Instagram: @OEMDefined - Facebook: https://www.facebook.com/OemDefined/ -
Interesting........Wotsirb wrote:Well... It does. It's well reported online? My solenoid went so the flap didn't activate at 5k... So I didn't get a kick... Solenoid now replaced and working and the kick is back.Rick_RS4 wrote:the flap on the airbox has nothing to do with the so called kick
rick is right.Starry wrote:Interesting........Wotsirb wrote:Well... It does. It's well reported online? My solenoid went so the flap didn't activate at 5k... So I didn't get a kick... Solenoid now replaced and working and the kick is back.Rick_RS4 wrote:the flap on the airbox has nothing to do with the so called kick
b7rs4 phantom black, titan pack.
I've never been able to feel it. Pretty sure it's there if I think about it, but when the engine hits 5k rpm I'm too busy concentrating on the road to be wondering if there is or isn't a kick.
Users browsing this forum: Bing [Bot] and 184 guests
