5k kick with stage 2?
Starry
Post by Starry » Thu Sep 01, 2016 12:55 pm
Should I be feeling a kick at 5k with an MRC stage 2?
Looking at the dyno graph there seems to be a decent increase at around that spot. Is the kick from the secondary flap in the airbox or from the map/ecu. Do people with CAI and flap delete still get the kick?
Mines going up to MRC on Monday to have a look at it so I'm trying to give them as much info as I can on the car as I'm sure there's an intermittent problem somewhere.
2006 RS4
Phantom black
Starry
Re: 5k kick with stage 2?
Post by Starry » Thu Sep 01, 2016 8:51 pm
No one?
2006 RS4
Phantom black
Rick_RS4
Post by Rick_RS4 » Thu Sep 01, 2016 9:45 pm
the flap on the airbox has nothing to do with the so called kick
yes i do still get the kick with it all removed
mrc will know what theyre on about so no need to worry
Starry
Post by Starry » Thu Sep 01, 2016 10:22 pm
Im sure they'll get to the bottom of it, I'm just trying to give them as much info as i can.
Pretty sure theres no vac leak as I've tested it as best i can. I was thinking maybe the solenoid on the airbox may of had a intermittent fault due to no 5k kick, that was the thinking behind the question. I did the Arthur test on a couple of occasions, 1st time i was getting 8.4-8.5 times, that was early morning and quite cool. Next i did a run on the same road each way and it was hot, around 27* and got 7.8 both times. The car feels faster some times than others...
2006 RS4
Phantom black
Post by MikeFish » Thu Sep 01, 2016 10:24 pm
Sounds like plain old heat soak?
Starry
Post by Starry » Thu Sep 01, 2016 10:34 pm
MikeFish wrote:Sounds like plain old heat soak?
No i don't think so, both times the car was driven there on a dual carriage way and was not sat around or hammered before the test, also the hot day produced the faster times..
2006 RS4
Phantom black
Matt_lad
Post by Matt_lad » Thu Sep 01, 2016 10:52 pm
The kick is still there on mine with MRC stage 2, CAF and flap removed etc...
Hope you get to the bottom of it, mine feels like a new car since coming back from MRC, totally different animal.
B7 RS4 - Sprint Blue Saloon
MRC Stg2 map : Pre-cat delete : MRC Stg2 Inlet : CAF : 437PS/462Nm
Int. & Ext. LED's : KW V3's : H&R Spacers 8mm
Wotsirb
Post by Wotsirb » Fri Sep 02, 2016 10:44 pm
Rick_RS4 wrote:the flap on the airbox has nothing to do with the so called kick
Well... It does. It's well reported online? My solenoid went so the flap didn't activate at 5k... So I didn't get a kick... Solenoid now replaced and working and the kick is back.
It lets in more air... =bigger bang... =more power...=kick...
Toy: '07 B7 RS4 Avant Sprint Blue
Daily: 06 B7 2.0T Special Edition Avant
Previous: '09 B8 2.0T Quattro S line Avant
- OEM Defined - Instagram: @OEMDefined - Facebook: https://www.facebook.com/OemDefined/ -
Starry
Post by Starry » Fri Sep 02, 2016 10:50 pm
Interesting........
2006 RS4
Phantom black
sar
Post by sar » Sat Sep 03, 2016 11:16 am
Interesting........
rick is right.
Starry
Post by Starry » Sat Sep 03, 2016 2:32 pm
[/rick is right./quote]
Well thats good if thats the case as I'm not feeling it, its there on the graph though. This is what makes me think somethings not right..
2006 RS4
Phantom black
Post by MikeFish » Sat Sep 03, 2016 3:44 pm
I've never been able to feel it. Pretty sure it's there if I think about it, but when the engine hits 5k rpm I'm too busy concentrating on the road to be wondering if there is or isn't a kick.
Users browsing this forum: 666Lenine, Zyox and 205 guests
