Brake Accuator - warning light
2.2 I5 20v turbo - 315 bhp
Msaville
Post by Msaville » Mon Mar 24, 2003 12:00 pm
Hi There
My brake warning light lights up and beeps when I start the car up cold and leave it to idle a few minutes in the morning. I have been led to believe this may be the "acctuator".
Im not to sure what that part does. Please could someone give me their thoughts on this - especially if you have also had this issue.
Macca the Kiwi
Kramrs2
Re: Brake Accuator - warning light
Post by Kramrs2 » Tue Mar 25, 2003 6:48 pm
Hi,
I think that your problem is a low level in the hidraulic tank of the steering system. Try to check the level and search for leaks.
Regards
johneroberts
Post by johneroberts » Wed Mar 26, 2003 12:03 am
Hydralic fluid leekage some where [img]images/graemlins/icon_lol.gif[/img]
Jr
Driving is believing
RS246 Founder
Jani
Post by Jani » Wed Mar 26, 2003 8:11 am
Also check brake fluid level.
Could be accumulator as well. This can be tested by pressing the brake pedal after car is turned off, you should get at least 5-10 brake assisted pushes, after the pressure accumulator is empty, the pedal will feel very heavy.
Msaville
Post by Msaville » Wed Mar 26, 2003 1:06 pm
Jani and co. Thanks for the tips. Its very intermittent but only when idling cold and stationary. It dissapears once on the move. Ill try testing the accumulator.
macca the Kiwi
Greg_S
Post by Greg_S » Fri Mar 28, 2003 11:51 pm
also worth checking your brake 'bomb' once you have checked your levels.
after a run if you car, stop and turn engine off and pump the brake pedal until it goes solid. should be about 35-40 pumps
Bullshit baffles brains
NIKOLAS
Post by NIKOLAS » Mon Dec 15, 2003 2:48 am
HI macca my name is nick and i live in Ctete Greece. I recently bought a RS2. I am facing the same problem with the warning light. DId you find the solution in yours ? what was the problem? Thanks Nick
timucin
Post by timucin » Mon Dec 15, 2003 3:34 am
LOL!
i have the same problem!
checked everything but still
[img]images/graemlins/smile.gif[/img]
Quattro
timucin
Post by timucin » Mon Dec 15, 2003 3:37 am
here is the link to my post,i was trying to explain the same thing
http://forums.rs246.com/forums/showflat ... o=&fpart=1
Quattro
Users browsing this forum: No registered users and 107 guests
