Gruppe-M induction
Re: Gruppe-M induction
Thanks. Do you know if it is an easy swap over ?
2007 black RS4 saloon. Bilstein Coilovers, MRC Re-map, Miltek non resonated valved exhaust with de-cats, Gruppe-M carbon induction, JHM manifold spacers, Stage 2 manifold, cold air feed.
Its not to bad just take your time it is fiddly!! i done mine when the inlet was off for carbon clean.
Typical... I've just had a carbon clean done. Just been out driving it and the traction control light has come on again... Last time it did this, VCDS said air mass fault, which i replaced with a new one. Not sure if the pcv would bring up an air mass fault on VCDS or not..?
I would try a mass airflow sensor first then, easyer job.
Already put a brand new one in less than a week ago.
Were you really gentle when you put the new one in? Perhaps the wiring was damaged slightly?
Yeah, treated it pretty carefully...
- Surrey Sam
Have you recently oiled the filter element?
Just before it went and had a carbon clean in may
if not a genuine sensor they can be poor...
Genuine audi. I have read up on the filter oil destroying the maf, and there is no proof that such a thing happens... Especially after putting in a new on for under 100 miles
Also, i un plugged the maf today whilst it was revving up and down on idle, and it was still revving up and down with it un-plugged..
There's a few members on here that had their MAF sensors distorted by filter oil from the Revolution induction kit, Youngben had two distorted within months and that's why they are supplied with dry filters now. When I washed and re-oiled mine, I had to leave it standing for a week. There were loads of oil and had to use compressed air to blow off the excess oil before refitting it.Frostie wrote:Genuine audi. I have read up on the filter oil destroying the maf, and there is no proof that such a thing happens... Especially after putting in a new on for under 100 miles
Phantom Black R8 V10 plus, Capristo Exhaust
Phantom Black (B7) RS4 Saloon, MRC Stage 2
Mercedes E-Coupe 350CDi
Users browsing this forum: Google [Bot] and 112 guests
