Carbon Cleaning 2014 RS4
Hi all,
Just picking up a 2014 RS4 in Viper Green with 15k on the clock. Having looked around the forums on the car before purchase there seems to be a lot of talk about carbon buildup.
Can anybody summarize the issues, frequency and specialists with regards the issue? Is it something I should be worried about?
Adam
Adam
2014 Audi RS4 Avant Viper Green "The Hulk" ● BMC Filters ● 034 Motorsport gearbox mount ●
2014 Audi S1 Mythos Black "Fuzz" ● Revo Induction ● BMC Filter ●
1995 Land Rover Discovery 300TDI "Gunbus" ● Under Restoration to original OEM Condition ●
Re: Carbon Cleaning 2014 RS4
Only on b7 cars talking about carbon build-up. Good luck with new car pictures please
rs4 b8 Suzuka, grey 14
Picture in the welcome thread...
- Surrey Sam
It's an issue that can affect all FSI cars, although it seems to have been most prevalent/talked about on the previous generation B7 RS4.
There's a forum member who's had their RS5 which shares with the B8 RS4 the later engine, inspected and cleaned for carbon by MRC. There was still carbon build-up happening on this engine but perhaps not quite as bad. The only way you'll ever really notice is when you get the car dyno'd, as it will be slightly down on claimed power. That being said, I seen members who've had their B8's dyno'd after 12k miles and still hitting manufacturer claimed figures, so think a lot comes down to how the car is used.
If the car see's regular "Italian tunes" and lengthy journey times, then it will be cleaner than say one which is used by a wife to potter around town and occasional drive outs.
Also a recent thread by Riv states that his car is getting faster rather than slower with age suggesting carbon is not a big issue with the B8.
That's great if they've sorted it on the B8.
Anyone had the manifold off one to have a look? Or dyno'd at higher mileage?
Would be good to have some data points
2007 RS4 B7 Avant
Car will do around 70 miles daily on a commute to work
I had mine on the rollers at MRC with 16k on it, made 429ps.
As with Silas mine feels quicker now at 20k miles and she gets driven properly.
2016 BMW F80 M3
2014 B8 RS4 - Milltek Non-Res - KW V2's with DRC delete - Setup by Centre Gravity. - Sold
2013 Q5 2.0 Tdi
1997 BMW E36 328i track car
2013 Q5 2.0 Tdi
I had my RS5 Carbon Cleaned around around 43k miles, with some others tweaks the car made a single run of 460PS (its highest that day) on the rollers, jump forward to this year and at around 54k miles back on the same rolling road similar conditions car made 423PS. I will say this though during the initial dyno tune by MRC it took Doug a few goes to get the car to make a consistent figure, initially it was at 401PS but with no changes at all and after a handful of runs it was running 422PS and I do 'tune' the car on a regular basis. This meant the car can vary by 20PS between runs. From when I purchased the car the initial stage 2 took this from 422PS to 438PS and unhappy with this I then had them dive in and do a carbon clean, filter change, exhaust (done elsewhere) and s tronic remap which got me to 460PS. I will also add that this year on the dyno the reverse was true, the cars first run was the strongest at 423PS and then the second and third was less again to a total of around 20PS. But it sounds good
Hope this helps
These cars need driving hard, my mates old b7 didn't have much build up at 40k and spanked the Arse of it on a daily basisI had mine on the rollers at MRC with 16k on it, made 429ps.
Do you still drive daily with your gearbox set in dynamic Silas?
Yes gaz,it's just in Audi having the oil dropped 10k before it needs doing, I'm just being careful mate.Do you still drive daily with your gearbox set in dynamic Silas?
You still having problems?
Yes buddy and still intermittent. Until it is a steady fault I won't do anything. I wonder if it will effect the clutch life as its an expensive job.
I'm not sure Gaz, last thing you want is a scary billYes buddy and still intermittent. Until it is a steady fault I won't do anything. I wonder if it will effect the clutch life as its an expensive job.
I just got my car back from having the G box oil changed, I have to say it feels
Much smoother with shifting, I think it was worth doing early.
Users browsing this forum: Google Adsense [Bot] and 85 guests
