Maximum gearbox torque before slipping
Re: Maximum gearbox torque before slipping
Post by Shoppinit » Wed Feb 17, 2016 9:23 am
blm70 wrote: Just received a quote from MRC...
Eye watering...
Steveo
Post by Steveo » Wed Feb 17, 2016 12:14 pm
ahoooga wrote:
S4WON wrote:Ouch. Can almost buy a whole new C5 for that...
Probably, but will it have a decent gearbox though for that money ? :bigblink:
I'd want an uprated one for that money!
RS6 C5, MTM
SuprSi
Post by SuprSi » Wed Feb 17, 2016 12:42 pm
Might as well go the whole hog, get a 517 box from the states and go nuts with hybrid turbos, tubular manifolds, water/meth, wagner IC's...
Is it worth it though? As you said you're already substantially more torque than standard, and on a stage 1 tune you'll only get ~30-40NM more torque, I doubt you'd even feel it.
Post by Shoppinit » Wed Feb 17, 2016 1:30 pm
But maybe he's wondering why it's slipping and when it'll fail completely...
Post by Shoppinit » Wed Feb 17, 2016 1:31 pm
Maybe a 517 valve body would be a good interim compromise.
Jay_g
Post by Jay_g » Wed Feb 17, 2016 3:59 pm
I wonder how much the 517 body is?
Post by bam_bam » Wed Feb 17, 2016 4:26 pm
Not much. I paid 900USD back in 2013, the shipping with FEDEX was about £70 each way. Just be careful with how you document the item, you need to state it's of small commercial and return for repair so you don't a raping off customs and excises. Don't list it as no commercial value, it attracts too much attention and the thing looks like a fucken bomb circuit as it is. For your shipping estimations, it weighs 12kgs if drained correctly and most importantly, wrap the sh1t out it, like you need it to survive a drop from the edge of space. I suggest wrapping it in loads of bubble wrap and then packing into a box with those edible styrofoam fuckers. If a solenoid gets broken off then it's bye bye valvebody.
SuprSi
Post by SuprSi » Wed Feb 17, 2016 5:16 pm
Cool, good info!
On the 517 trans website it just calls it a ' valve body recalibration', so does it actually improve clamping force and driveability?
I wish more than anything that mrc could get it to blippy downshift. The rs6 study guide says it should but I guess it must have been difficult to implement perhaps.
Post by bam_bam » Wed Feb 17, 2016 5:34 pm
Shifts were meant to be more 'positive' but I couldn't tell, mostly because I never drove tiptro C5 RS6 back to back. It didn't change any other driving characteristics but I never experienced any slip running 605PS and 848Nm so I guess that's what counts, even after 15mins on track. I could have the TC locked aat low speeds in 3rd, 4th or 5th and floor it without any slip anywhere on the rev range. These were all things that I'd noticed would cause 'issues' prior to the uprated VB.
I don't think the blip downshift is really required, is it? The TCU just has presets it will change down to, the 'loon always sounded like death when down changing anyways. I wish MRC could add no-lift changes for the C5 manual, that'd make my day, or maybe that Nissan SynchroRev Match (SRM) stylee.
TomRS
Post by TomRS » Wed Feb 17, 2016 5:35 pm
SuprSi wrote:Cool, good info!
Throttle blips are just tps controlled inputs during gearchange... obviously a full calc would have to be made so no matter the rev's it was matched correctly with the throttle input.
I can imagine it being quite hard, could a baseline not be taking from the C6 which has this?
I actually thought C5's blipped in manual mode... learn something new everyday,
As bam says SRM would be cool as hell!
Audi RS4 B5 + Audi Q7 4.2TDi
Gone but not forgotten :smile_smoking:
2010 Nissan GT-R SVM 680R
blm70
Post by blm70 » Wed Feb 17, 2016 7:29 pm
Shoppinit wrote:But maybe he's wondering why it's slipping and when it'll fail completely...
This.
It's not slipping at the moment with 'only' 782Nm which is fine, but it's always going to be in the back of my mind. Just got to decide whether to go exchange Audi box or rebuilt with 517...
Ironically, the rebuild has 18 months left on a 2 year warranty but as they've proven incapable of rebuilding it properly there's no way I'm going back there. Ever.
Current:
TT Mk1, 225 Quattro Misano Red, AmD map
Former:
RS6 Avant 2004, MRC Stage 1+, Bilstein Coilovers, Milltek & s/s downpipes
Saab 9000 Aero 1997, GT3071, Siemens Dekka 630s, Forge 50mm i/c, 3" downpipe, Maptun stainless header, Konis, Quaife lsd, a/c deleted, 4.05 ratio 'box, custom map, 470hp & 440lb/ft.
Saab 9-3 Aero Estate 2.8 v6 2006, 3" stainless downpipe & remap, 302hp & 380lb/ft.
Rouse Sport 304R Sapphire Cosworth 1990 (stock), 260hp & 300lb/ft.
Jay_g
Post by Jay_g » Wed Feb 17, 2016 9:24 pm
Who did you use mate? Is it the people AMD use?
517 is $900 for valve body recalibration. Certainly something to think about if it ever goes.
blm70
Post by blm70 » Wed Feb 17, 2016 10:19 pm
Jay_g wrote:Who did you use mate? Is it the people AMD use?
JT Automatics in Erith, Kent. Yes, after making some enquiries I found that AmD outsource the work to another company who in turn get JT to do the rebuild. That's why I went to them directly as it worked out a few hundred pounds cheaper. Hmm...
Jay_g wrote:517 is $900 for valve body recalibration. Certainly something to think about if it ever goes.
So £650-ish plus shipping. Is it then just a case of removing the box, swapping the valve bodies and refitting? JT charged £1200 + vat to remove and refit (ballpark figure I'm guessing.) Would also need to factor in cost of swapping valve bodies plus any other work that might need doing e.g. clutches.
bam (or anyone) - who did you get to fit the 517 please and roughly what did it all cost?
Current:
Former:
Post by bam_bam » Wed Feb 17, 2016 10:24 pm
MRC and I rolled it into a gearbox service.
Post by Shoppinit » Wed Feb 17, 2016 10:25 pm
You don't need to remove the box. Just the sump.
Users browsing this forum: No registered users and 1428 guests
