So i was blessed with the dreaded oil leak
Does anyone knows the part numbers of the oil seals needed for the repair
Can anyone point them on the part list.
Thanks in advance
Can you guide me in what to change while engine is out with the part numbersFarravi wrote:Had quite a few bits to it, the seals don't cost too much and you're better off changing the bits and bobs whilst the engine bay is out for the sake of hundred pounds, you're minimising future failure as these seals eventually wear out, losing their purpose.
Thanks mateFarravi wrote:
There you go mate, except for the thermostat I think all the parts were pertaining to the oil leak, can't say if all the seals were used but seeing th y are a few squid you will save yourself future headache knowing you changed the seals/gaskets.
Some part numbers are the revised/updated parts i.e. Most current part no. I used TPS by the by. Good-luck.
Users browsing this forum: IanH755 and 218 guests
