Oil pump seals Part Number
5.0 V10 50v biturbo - 571 bhp
tiago719
Post by tiago719 » Fri Jan 15, 2016 11:14 pm
Hi guys
So i was blessed with the dreaded oil leak :bash:
Does anyone knows the part numbers of the oil seals needed for the repair
Can anyone point them on the part list.
Thanks in advance
2008 Rs6 4f Mrc 750 bhp 1050 nm Supersprint non resonated and 2ndary cats delete.
2010 Megane Rs Cup chassis stage 1 300 bhp
IanH755
Re: Oil pump seals Part Number
Post by IanH755 » Sat Jan 16, 2016 2:18 am
The receipt RS6chris! had for his oil pump seal had it down as item 40 part number - N 90460801
Farravi
Post by Farravi » Sat Jan 16, 2016 4:22 am
Had quite a few bits to it, the seals don't cost too much and you're better off changing the bits and bobs whilst the engine bay is out for the sake of hundred pounds, you're minimising future failure as these seals eventually wear out, losing their purpose.
tiago719
Post by tiago719 » Sat Jan 16, 2016 9:57 pm
Farravi wrote:Had quite a few bits to it, the seals don't cost too much and you're better off changing the bits and bobs whilst the engine bay is out for the sake of hundred pounds, you're minimising future failure as these seals eventually wear out, losing their purpose.
Can you guide me in what to change while engine is out with the part numbers
I'm also doing the downpipes performance wise
Farravi
Post by Farravi » Sun Jan 17, 2016 6:01 pm
There you go mate, except for the thermostat I think all the parts were pertaining to the oil leak, can't say if all the seals were used but seeing they are a few squid, I strongly advice to replace them for good measure.
Some part numbers are the revised/updated parts i.e. Most current part no. I used TPS by the by. Good-luck.
tiago719
Post by tiago719 » Tue Jan 19, 2016 12:23 am
Farravi wrote:Image
There you go mate, except for the thermostat I think all the parts were pertaining to the oil leak, can't say if all the seals were used but seeing th y are a few squid you will save yourself future headache knowing you changed the seals/gaskets.
Thanks mate
burnsiet
Post by burnsiet » Wed Feb 26, 2020 4:58 am
Hi, sorry to dig up an old thread, but I can't find any info on part 07L103081 Oil Strainer.
Why do we require 8 of these? The parts drawings show 1.......I think.
I have to pull my engine out for transmission overhaul and want to cover all the usual bases while it is out. I am just ordering parts now.
I will drop in and post a hi in the welcome area. When i get a couple of things sorted.
Jim Haseltine
Post by Jim Haseltine » Wed Feb 26, 2020 9:41 am
The diagram only shows 1 but there are 8 ports and each has a strainer fitted.
burnsiet
Post by burnsiet » Thu Feb 27, 2020 10:04 pm
Great, thanks Jim.
20 minutes after posting my question, the very next photo I looked at showed all 8.
c3nturi0n
Post by c3nturi0n » Tue Mar 03, 2020 2:46 pm
Good to know - thanks chaps.
I'm also looking to drop the engine in mine to address the faulty PAS pump. Other than the list of parts stated above, any other jobs worth looking into or addressing while both engine + g/box are 'down'? e.g. engine mounts, anything to do with turbo's, exhaust downpipes maybe etc.
Thanks much!
2008 RS6 Avant (Monza Silver)
- Stage II MRC tune with gearbox (720PS/850Nm)
- MIJ Powerflow exhaust (non-res)
- H&R ARBs
Users browsing this forum: IanH755 and 220 guests
