Complete front arm change
Hi all, has anyone done the above ? I started on mine today and had a few problems .
The front lower arm is all free but I cant seem to release it ? does the shock have to be removed first ?
The rear lower arm is also being a pain , even a ball joint spliter cant free it and where it bolts to the front sub frame I cant remove the bolt as it seems to long and catches on the floor .
Any advice would be good ,ive left it for now as it was bloody freezing up the garage today .
Re: Complete front arm change
When I did my lower arms I'm sure I dropped subframe a little you will find it easier getting bolt out
Sprint blue,kw clubsports,milltek non resonated,k&n,dectane rears,led drl,20x9 rohana rc10 et25 ebc yellowstuff pads f+r revo tune
I was booked in to have them fitted last Wednesday but had to go up north for work . so thought id give it a shot over the weekend . The car is left up on jacks and I have someone coming round Wednesday this week to fit them . to much headache for me
Also noticed my front driveshaft gator is leaking so I went to Audi and collected one today , ive found a new right front shock too and just need to find someone selling a new front left . ill replace the lot while its in bits just so I don't have a future problems .
Just had mine all done at Mrc
If I was you you would be better off doin them yourself as it will
Cost you in excess of £1k
Save your self a few quid
At 200mph you have no friends
£250 all fitted , been quoted this by 3 garages and 1 mobile mech . if you paid 1k you need a refund of 75%
All done except the passenger top arms as that bolt will not budge , any tips ?
voidopolis
Are you talking about the knuckle (pinch) bolt that holds the upper arms? I've read a number of different approaches. One is a special (expensive) tool from Audi that clamps on and you use a air tool to extract it. the other method I've seen is to heat it up with a torch and spray the hell out of it with PB-Blaster...
https://www.youtube.com/watch?v=OtwR4bgA_x0
I just watched this video today of a guy doing the torch method.
Hi thanks for the reply , I spent an hour last night , managed to get it free and out !!! Some thing the mobile mech couldn't do . he said he would show up today to fit the arms and guess what No SHOW so ill do them tomorrow myself .
So ive completed all the top and lower arms both side , all that is left to do is the passenger track rod end , one side is a 13 mm bolt and the other side (the back) is like half moon shaped . when turning the 13 mm bolt its just spinning . Has anyone done this ? is the a special socket ? as everything ive tried to grip it with just slips off
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 308 guests
