European Sat Nav Map?
Post by MikeFish » Sat Jan 02, 2016 2:43 pm
Does the C7 come with sat nav maps covering all of Europe? In particular I'm interested in France, Belgium, Holland & Germany. I can't seem to find this info anywhere.
I have a wedding in dusseldorf in May and am thinking it might be a nice little road trip.
Moonmonkey831
Post by Moonmonkey831 » Sat Jan 02, 2016 3:46 pm
Pretty sure it will. I've driven to France in my rs4 and all was there, so the c7 must as a newer tech. Have you tried planning a route and zooming into the destination to confirm?
Current: 2017 RS6 Performance in Nardo Grey
Previous: 2014 RS4 in Sepang Blue; 2011 Q5 3.0TDi Sline Plus in Ibis White; 2007 Audi S5 4.2 V8 in Phantom Black; 2006 VW Golf GTi in Tornado Red; 1998 VW Golf 1.9 TDi in Navy Blue; 1988 VW Polo 1.0 in Gold
asifg
Re: European Sat Nav Map?
Post by asifg » Sat Jan 02, 2016 4:29 pm
If it doesn't use Navmii for free SatNav from your mobile, or if you have a good data roaming deal with your network, use Waze. I have Built-in Nav on both of my cars but only ever use Waze
Post by MikeFish » Sat Jan 02, 2016 4:39 pm
Moonmonkey831 wrote:Pretty sure it will. I've driven to France in my rs4 and all was there, so the c7 must as a newer tech. Have you tried planning a route and zooming into the destination to confirm?
Thanks, not taken delivery yet so can't check for now.
Post by MikeFish » Sat Jan 02, 2016 4:40 pm
asifg wrote:If it doesn't use Navmii for free SatNav from your mobile, or if you have a good data roaming deal with your network, use Waze. I have Built-in Nav on both of my cars but only ever use Waze
Thanks but I'd rather use the built in nav if I can. Can you use Google Maps via connect even if you don't have the map on the HDD?
Or alternatively I'll buy the appropriate map.
Moonmonkey831
Post by Moonmonkey831 » Sat Jan 02, 2016 4:42 pm
Ahh fair enough! I'd be 99.9% sure you'll be fine
Post by HYFR » Sat Jan 02, 2016 4:50 pm
Yes it does
Post by MikeFish » Sat Jan 02, 2016 5:21 pm
Ok thanks Dave.
Heden
Post by Heden » Sun Jan 03, 2016 11:52 pm
Just came back after driving through all those countries, and I can confirm that the Sat Nav have full coverage.
Post by MikeFish » Mon Jan 04, 2016 12:04 am
Thanks. Any special tips eg which countries require special equipment like high vis vests etc?
Did the headlights automatically adjust to driving on the left or did you have to manually set it through the MMI?
Heden
Post by Heden » Mon Jan 04, 2016 11:53 pm
MikeFish wrote:Thanks. Any special tips eg which countries require special equipment like high vis vests etc?
France requires you to have high vis vest and breathalysers, so I recommend having those in the car at all times.
The headlights changes automatically based on the country the car is in (takes it from the sat nav). It works a treat and the LED Matrix is awesome :kissmyrings:
Post by MikeFish » Tue Jan 05, 2016 12:28 am
Thanks Heden
wildbore
Post by wildbore » Tue Jan 05, 2016 9:06 am
And the high-vis jackets MUST be accessible from the driver's seat. Putting them in the boot is not acceptable. I expect it's only the must curmudgeonly of Gendarme's who would have you on this technicality, though.
Post by MikeFish » Tue Jan 05, 2016 9:30 am
Thanks. I found a nice guide to each of the countries on the AA website which explains all the little bits I need to know. It says exactly what you said that the hi-vis needs to be in the car not the boot so you can wear it before you get out of the car in the event of a breakdown. And about the breathalysers etc.
wildbore
Post by wildbore » Tue Jan 05, 2016 9:45 am
Those high-vis jackets are not just for breakdowns. When the Clifford BlackJack kicks in, the criminals can make safe and orderly exit from the vehicle wearing high vis jackets to ensure they can be seen by other road users whilst they deploy the emergency warning triangle.
Users browsing this forum: No registered users and 88 guests
