vagcom headlight adaption help
qaiserrs6
Post by qaiserrs6 » Sun Dec 27, 2015 9:26 pm
Hi iv got the warning light on the dash code p01539 headlights not adjusted and I cant seem to reset the problem.
Has anyone got the original stored headlight range adaption values for channels 1-7.
Current: Mrc'd 676 bhp B5 RS4 Nogaro Blue, 19" MTM Bimoto, Rns-E, Rs4 Bucket seats, Ceramics, Bilstein Pss9's, TTE780+, KKD Manifolds, Wossner 82mm pistons, Uprated h'beam rods, 3" downpipes, Milltek cat back, Wagner intercoolers, 63mm bi-pipes, 63.5mm Intakes, 95mm MAF, 875cc dekas, Veyron HPFP
Re: vagcom headlight adaption help
Post by Shoppinit » Sun Dec 27, 2015 9:44 pm
Have you gone through the learning procedure?
Any error codes?
qaiserrs6
Post by qaiserrs6 » Sun Dec 27, 2015 9:51 pm
yes it shows error group 001 not available.
a friend of mine tried having a go and hes changed the headlight range adaption channel values, so wanted to change them back to standard first
Post by Shoppinit » Sun Dec 27, 2015 9:58 pm
Are you in adaptation or basic settings?
/is this for a RS6?
qaiserrs6
Post by qaiserrs6 » Sun Dec 27, 2015 10:05 pm
Yes for rs6 c5
Im in adaptation
Trups
Trader (Expired)
Post by Trups » Sun Dec 27, 2015 10:07 pm
If you have an error on the dash it won't let you Adapt, is the car lowered?
Post by Shoppinit » Sun Dec 27, 2015 10:07 pm
That's where you're going wrong. Go to basic settings, group 001 then Go. Then up arrow to go to group 002 and that will learn the position.
qaiserrs6
Post by qaiserrs6 » Sun Dec 27, 2015 10:11 pm
55-headlight range adaptation
mine is showing these values
channel = stored value
01 = 1
02 = 0
03 = 0
04 = 46
05 = 2
06 = 1
07 = 1
qaiserrs6
Post by qaiserrs6 » Sun Dec 27, 2015 10:14 pm
Yes the car is lowered
qaiserrs6
Post by qaiserrs6 » Sun Dec 27, 2015 10:16 pm
Shoppinit wrote:That's where you're going wrong. Go to basic settings, group 001 then Go. Then up arrow to go to group 002 and that will learn the position.
I have tried that it says error group 001 not available
Post by Shoppinit » Sun Dec 27, 2015 10:18 pm
Look in the measuring blocks to see what the level senders are reading.
qaiserrs6
Post by qaiserrs6 » Sun Dec 27, 2015 10:22 pm
fronts are 1.72v and the rears 3.77v
Post by Shoppinit » Sun Dec 27, 2015 10:25 pm
That might be your problem. I think they have to be close to 2.5 to be able to learn the position.
Is your car level? I'm slightly surprised at the much higher reading at the rear, but maybe it's normal that it goes the other way.
Post by Shoppinit » Sun Dec 27, 2015 10:26 pm
if you can be bothered, might be worth jacking the car at a strategic point to get the values closer to 2.5 front and rear to see if you can complete the basic settings.
qaiserrs6
Post by qaiserrs6 » Sun Dec 27, 2015 10:31 pm
ok I will give that a try, are my headlight range adaption values right?
Users browsing this forum: Google [Bot] and 222 guests
