Multi function steering wheel swap
Re: Multi function steering wheel swap
Post by bam_bam » Fri Dec 18, 2015 9:21 am
chunky79 wrote:
bam_bam wrote:I thought he had a tintop 3 series.
Still an M3. M3 = gheyness.
And before people start the, have you ever driven one?, they are brilliant cars. No I haven't, cause I is not a gheyer.
Shopp is very helpful though and has a lovely glandshake
FIXED.
bilko1
Post by bilko1 » Sun Dec 20, 2015 9:20 am
pete62 wrote:So does the MFSW just work on a car not originally spec'd with one or does it mean altering sh1t like wiring, rings airbag stuff etc etc?
Chances are you will need the steering wheel control module changing as well.
Jultsu
Post by Jultsu » Sun Dec 20, 2015 11:03 am
On a non-MSWF A6 you'll need the Multifunction relay, base for the relay, cables to be cut'n'hacked alongside the OEM wiring and a new stalk.
swannny
Post by swannny » Sun Dec 20, 2015 3:14 pm
Nobody in their right mind would go through all that hassle for a fugly steering wheel..would they?
Post by Shoppinit » Sun Dec 20, 2015 3:49 pm
swannny wrote:Nobody in their right mind would go through all that hassle for a fugly steering wheel..would they?
That's what I thought, but it turns out some people actually like the poverty spec 3-spoke wheel.
Anyway, IIRC the RS6 has the steering ring that will accept either. Need to confirm that.
Post by chunky79 » Sun Dec 20, 2015 4:03 pm
Pretty sure Amar had to change his slip ring.
Post by bam_bam » Sun Dec 20, 2015 6:44 pm
chunky79 wrote:Pretty sure Amar had to change his slip ring.
Really?!?! You just had to lower the tone and take this thread off topic.
pete62
Post by pete62 » Sun Dec 20, 2015 8:00 pm
Jultsu wrote:On a non-MSWF A6 you'll need the Multifunction relay, base for the relay, cables to be cut'n'hacked alongside the OEM wiring and a new stalk.
Thanks guys!
I'd consider it if it were a simple change as the three spoke ain't exactly a looker. Form over function and all that. Would be nice to have controls on the wheel for the audio and keep the car relatively standard without the expense of the FBSW route.
Users browsing this forum: Bing [Bot] and 412 guests
