FIXED.chunky79 wrote:Still an M3. M3 = gheyness.bam_bam wrote:I thought he had a tintop 3 series.
And before people start the, have you ever driven one?, they are brilliant cars. No I haven't, cause I is not a gheyer.
Shopp is very helpful though and has a lovely glandshake
Multi function steering wheel swap
Re: Multi function steering wheel swap
Chances are you will need the steering wheel control module changing as well.pete62 wrote:So does the MFSW just work on a car not originally spec'd with one or does it mean altering sh1t like wiring, rings airbag stuff etc etc?
On a non-MSWF A6 you'll need the Multifunction relay, base for the relay, cables to be cut'n'hacked alongside the OEM wiring and a new stalk.
Nobody in their right mind would go through all that hassle for a fugly steering wheel..would they?
That's what I thought, but it turns out some people actually like the poverty spec 3-spoke wheel.swannny wrote:Nobody in their right mind would go through all that hassle for a fugly steering wheel..would they?
Anyway, IIRC the RS6 has the steering ring that will accept either. Need to confirm that.
Pretty sure Amar had to change his slip ring.
Really?!?! You just had to lower the tone and take this thread off topic.chunky79 wrote:Pretty sure Amar had to change his slip ring.
Jultsu wrote:On a non-MSWF A6 you'll need the Multifunction relay, base for the relay, cables to be cut'n'hacked alongside the OEM wiring and a new stalk.
Thanks guys!bilko1 wrote:Chances are you will need the steering wheel control module changing as well.pete62 wrote:So does the MFSW just work on a car not originally spec'd with one or does it mean altering sh1t like wiring, rings airbag stuff etc etc?
I'd consider it if it were a simple change as the three spoke ain't exactly a looker. Form over function and all that. Would be nice to have controls on the wheel for the audio and keep the car relatively standard without the expense of the FBSW route.
Users browsing this forum: Google Adsense [Bot] and 183 guests
