RS6 wheels
RS6 wheels
Will RS6 wheels fit RS4's? Sorry if it's a stupid question but if you don't know.
Re: RS6 wheels
Which RS6, which RS4, which wheels?
Re: RS6 wheels
Sorry, like I said, if you don't knowdoodlebug wrote:Which RS6, which RS4, which wheels?
Part Number is 4G9 601 025 N
Offset is 43
20" 8.5J
5 x 112
RS6 wheels
Need to check the centre bore as well. B7 RS4 is 57.1mm
You'll need some spacers to get those on, as standard B7 offset is ET29, and most people space out the OEM wheels 8 or 10mm to get them filling the arches right, creating an effective ET21 or 19mm. Therefore, you're looking at approx 20-25mm spacers. At that size I'd recommend H&R Trak+ or similar bolt on type spacers (bolt to the hub with their own small bolts, and then wheels bolt into the spacer).
2007 RS4 B7 Avant
Re: RS6 wheels
Don't forget that wheel is also half an inch narrower than the OEM wheel so will be 6mm further in.
FYI I doubt any RS6 came with an 8.5inch wide wheel with an offset of 43, they'd never clear the brake calipers.
Users browsing this forum: No registered users and 111 guests
