RS6 wheels
ChrisR
RS6 wheels
Post by ChrisR » Thu Dec 17, 2015 11:28 pm
Will RS6 wheels fit RS4's? Sorry if it's a stupid question but if you don't know.
doodlebug
Re: RS6 wheels
Post by doodlebug » Thu Dec 17, 2015 11:32 pm
Which RS6, which RS4, which wheels?
Re: RS6 wheels
Post by bam_bam » Thu Dec 17, 2015 11:33 pm
Ha.
ChrisR
Re: RS6 wheels
Post by ChrisR » Thu Dec 17, 2015 11:39 pm
doodlebug wrote:Which RS6, which RS4, which wheels?
Sorry, like I said, if you don't know :oops: my RS4 is a 2006 B7 Avant. Not sure on the RS6 but the details of the wheels are :
Part Number is 4G9 601 025 N
Offset is 43
20" 8.5J
5 x 112
FaisalJ
RS6 wheels
Post by FaisalJ » Fri Dec 18, 2015 1:39 am
Need to check the centre bore as well. B7 RS4 is 57.1mm
You'll need some spacers to get those on, as standard B7 offset is ET29, and most people space out the OEM wheels 8 or 10mm to get them filling the arches right, creating an effective ET21 or 19mm. Therefore, you're looking at approx 20-25mm spacers. At that size I'd recommend H&R Trak+ or similar bolt on type spacers (bolt to the hub with their own small bolts, and then wheels bolt into the spacer).
2007 RS4 B7 Avant
Re: RS6 wheels
Post by MikeFish » Fri Dec 18, 2015 6:48 am
Don't forget that wheel is also half an inch narrower than the OEM wheel so will be 6mm further in.
FYI I doubt any RS6 came with an 8.5inch wide wheel with an offset of 43, they'd never clear the brake calipers.
Return to “General Car Chat”
Users browsing this forum: No registered users and 7 guests
