Headlight Washers VCDS Question
Morning lads quick question regarding the highlight washers on my B8 S4. Recently had an RS4 style bumper fitted and the headlight washers are operating fine but won't retract back in as they keep getting stuck on the flaps in the bumper. Having had a look the body Shop have damaged the little bit of plastic the bumpers push again to open the flaps. Is there an option to disable them with VCDS as there useless anyway and it drains the windscreen washer tank or can I just disconnect them electronically?
Re: Headlight Washers VCDS Question
I've got the exact same issue!
I hardly use the washers with the headlights on so this is on the long-range "to do" list.
However, I believe you can disable the headlamps washers via VCDS, yes:
I've not tried this personally though, and don't forget you'll need them again come MOT timeDisable Headlight Washers
[09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 18
Bit 0 - Remove check mark (1 = headlight washers installed)
Cheers mate legend!
I have shaved the aliens so that they no longer catch the flap, NO detriment to operation been working for about
12 months now no issues
Good shout Rob!
Could you post a pic of your modified aliens as a guide please?
- Surrey Sam
Just to note.
If you have Xenons and deactivate the headlight wash facility, you will fail an MOT test.
Jay, I just got a dremmel and removed the underneath so it didn't catch will pull one out tonight and send an image.
Car is now booked in for H&R lowering springs, AP Racing 390mm Brake kit and then to MRC for mapping of gear box and engine and then to get it all Gtechniq'd
Big smiles ahead
Big smiles ahead
Picture would be awesome
cheshire_carper
How would the tester ever know? He would have to try so many times and even then it doesn't squirt!Surrey Sam wrote:Just to note.
- Surrey Sam
On my own car I de-activate the feature as I don't like it showering the clean bonnet. Two years running now, Audi have failed it for inoperable headlight washers as I always forget to re-activate them come MOT test time.cheshire_carper wrote:How would the tester ever know? He would have to try so many times and even then it doesn't squirt!Surrey Sam wrote:Just to note.
I think the count between last squirt is reset when either the lights are switched off or when the car is switched off and locked up.
Doesn't it squirt everytime you have a long squirt on the windscreen with the headlights on?
Either way, my old alfa failed the MOT because one washer didn't work. I'm not sure if it is only relevant to cars with xenons either. I thought if your car was fitted with headlight washers then they had to work to pass the MOT. I know cars with xenons must have washers and self-levelling but I thought the MOT requirements for washers was separate to that (but I could be wrong).
Users browsing this forum: No registered users and 43 guests
