Anyone bought a battery recently?
Post by Shoppinit » Mon Dec 07, 2015 12:03 pm
I need a new one. My trusty old Varta having finally given up the ghost.
By my reckoning, the life of this battery was extended by at least 5 years by having it on the conditioner all the time. However, it is a bit of a double-edged sword since having it always charged up and ready to go means that you don't get any warning signs that the battery is about to fail. This happened to me last time I took the car out. Started beautifully, took it out for a spin, then when I put it back in the garage I didn't put the conditioner on it. 24 hours later I went to the car to put it on the conditioner on and there wasn't even enough juice to work the central locking. Luckily, it happened in my garage and not parked in a car park or something.
Anyhoo, if anyone has bought a battery recently, what brand and model did you get? I'm veering towards the Varta again, but I'm open to other ideas.
Also, can anyone confirm it's 394mm long? I don't have access to the car at the mo.
CheeRS.
SuprSi
Re: Anyone bought a battery recently?
Post by SuprSi » Mon Dec 07, 2015 12:12 pm
I got one from Tayna batteries. It's an Enduroline battery, they're reasonably priced and work well in my experience. The regulator on my alternator is failing as you know.. it's drained the new battery dead flat at least 20 times and it's been run nearly flat 80+ times now and still has good capacity and starting power. I thought it'd be fubar by now to be honest! Dunno about the length, I just bought the size the website recommended and it was perfect. I'll measure it later if you want.
Edit, Bilko was right, the 020 is the correct size, not 019.
https://www.tayna.co.uk/020-Car-Batteries-G438.html
Post by Shoppinit » Mon Dec 07, 2015 12:18 pm
Thanks. :thanks: Although that one looks like it's too small.
I remember now that my battery is too small and it used to thump around in the boot when I was cornering. This was when I had just bought the car and I remember thinking it was the dreaded DRC.
I've noticed all the car parts sites recommend the wrong size battery. Nothing is easy.
SuprSi
Post by SuprSi » Mon Dec 07, 2015 12:20 pm
I'll pop out to the car at 12 and measure it up for ya :)
I had the same with the battery that came with the car, it was a Bosch S4 I think, wedged in with a piece of scrap wood that kept coming out, not very clever.
bilko1
Post by bilko1 » Mon Dec 07, 2015 12:46 pm
L393 W175 H190 this is a 020 type battery but a lot of battery catalogues list an 019 for the RS6 which is smaller and wrong. This is the catalogue I use at work http://batterylookupgb.yuasa.co.uk but it can be wrong as you will see when you look at yours. They list 019 but if you look at trim versions you will see the correct 020 listed.
SuprSi
Post by SuprSi » Mon Dec 07, 2015 1:09 pm
Bilko's right, it's an 020.
I measured roughly with a ruler, it's 19cm high, 17cm deep and ~400cm wide.
Post by Shoppinit » Mon Dec 07, 2015 2:43 pm
Awesome. Thanks, chaps. :bowdown:
ahoooga
Post by ahoooga » Mon Dec 07, 2015 4:14 pm
you 'could' look in the 'Spec and FAQ sticky :bigblink:
Theres a section in the 'RS6 useful info and links' that a guy called Shoppinit wrote regarding batteries.
Battery
110Ah
Varta VA0 DE 000 915 105 AK
Dimensions: 394mm long, 175mm wide, 190mm high.
:assflash:
even better , 3rd post down on page 2
viewtopic.php?f=2&t=103817&hilit=battery&start=15#wrap
Post by MikeFish » Mon Dec 07, 2015 4:22 pm
ahoooga wrote:you 'could' look in the 'Spec and FAQ sticky :bigblink:
Battery
110Ah
:assflash:
LOL
I repaced mine with a Banner AGM batteries. I went with Banner as that was one of the few makes that are well regarded in the car audio that can be bought fairly easily in the UK. I chose an AGM battery as these are supposed to be better than their non AGM brothers as they can take a lot of abuse from these modern stop / start engines. The downside is that AGM normally cost more and only last about 5 years.
Post by bam_bam » Mon Dec 07, 2015 4:27 pm
Battery
110Ah
:assflash:
LOL
Ahhhh, so that's what that setting is on my battery charger.
SuprSi
Post by SuprSi » Mon Dec 07, 2015 4:39 pm
Battery
110Ah
:assflash:
LOL
It's good for calcium batteries too as they like higher charge voltages. The AGM setting is 14.8V instead of 14.4.
ahoooga
Post by ahoooga » Mon Dec 07, 2015 6:05 pm
bam_bam wrote: Ahhhh, so that's what that setting is on my battery charger.
AND Rampant Rabbit instant charger ....... in case you've got a toureg
Post by chunky79 » Mon Dec 07, 2015 9:26 pm
Battery
110Ah
:assflash:
Shopp, you mongtard.
Got my last battery Euro car parts I think, twas a Bosch that had to be replaced within the warranty.
Post by chunky79 » Wed Dec 09, 2015 7:36 am
So what battery you going for then Shopp?
Post by Shoppinit » Wed Dec 09, 2015 9:46 am
Think I'm gonna go for the Varta. It's the easiest one for me to get hold of and I like the brand.
ECP don't appear to list any batteries that are the right size. You got the right one?
Users browsing this forum: Majestic-12 [Bot] and 112 guests
