However on my run home tonight the headlights decided to start hunting up and down while driving.
The fault buzzer sounded and the fault symbol appeared on the dash. Anyone got any ideas what the issue is here? Your help is much appreciated.
Hi docurleydocurley wrote:I would guess the active leveler have a fault.
Thanks docurley I'll keep you posted as I am heading to the garage tomorrow so I'll get it checked out.docurley wrote:It would be part of the whole unit but I may have what you need has I have a box of headlight parts and I'm sure at least one has the motor.
It'll be plugged in tomorrow so I'll get back with an update and keep you posted.davers6 wrote:They made just need readaption you need to plug into to vcds and get fault code
Cheers Dave. It's def plugged in as it's an intermittent fault. I'll have a look over the weekend and see what's going on.davers6 wrote:Almost certainly the level sensor its on the near side front lower suspension arm they probably forgot to unplug it when engine removed or plug it back in when refitted
Won't be fully burned in yet as probably 20 hours on them but I hope this helps.marc1 wrote:^ MB2 get a picture up as per FaisalJ's post above.
Users browsing this forum: Bing [Bot] and 212 guests
