Headlights
Chuds1
Re: Headlights
Post by Chuds1 » Wed Nov 25, 2015 12:25 am
Ok so I've been in touch with Trups and he is keeping me right with what mods to go for.
However on my run home tonight the headlights decided to start hunting up and down while driving. :thumbsdown:
The fault buzzer sounded and the fault symbol appeared on the dash.
Anyone got any ideas what the issue is here? Your help is much appreciated.
RS4 B7 Saloon Sprint Blue, Bilstein B14 Coilovers, Milltek Cat Back resonated non valved. Spacers 8mm F and 10mm R. Headlight clear zenon lens upgrade with 5500k bulbs plus indicator orange lens delete.
docurley
Re: Headlights
Post by docurley » Wed Nov 25, 2015 12:49 am
I would guess the active leveler have a fault.
Chuds1
Re: Headlights
Post by Chuds1 » Wed Nov 25, 2015 12:59 am
docurley wrote:I would guess the active leveler have a fault.
Hi docurley
Can the levellers be bought separate do you know or are they part of the headlight?
Don't fancy buying a new set of headlights as I would probably have a heart attack at the price. :shock:
docurley
Re: Headlights
Post by docurley » Wed Nov 25, 2015 9:02 am
It would be part of the whole unit but I may have what you need has I have a box of headlight parts and I'm sure at least one has the motor.
davers6
Re: Headlights
Post by davers6 » Wed Nov 25, 2015 9:33 am
They made just need readaption you need to plug into to VCDS and get fault code
Chuds1
Re: Headlights
Post by Chuds1 » Wed Nov 25, 2015 9:59 pm
docurley wrote:It would be part of the whole unit but I may have what you need has I have a box of headlight parts and I'm sure at least one has the motor.
Thanks docurley I'll keep you posted as I am heading to the garage tomorrow so I'll get it checked out.
davers6 wrote:They made just need readaption you need to plug into to vcds and get fault code
It'll be plugged in tomorrow so I'll get back with an update and keep you posted.
Chuds1
Re: Headlights
Post by Chuds1 » Thu Nov 26, 2015 3:08 pm
Ok so had the car plugged in today and scanned. Came back with a fault on the lever sensor.
Where abouts is the lever sensor located? Would like to have a look before I go buying a new sensor.The car has just been in the garage for the timing chain replacement so I would imagine that this sensor would have been disturbed at some point.
There's always something.
davers6
Re: Headlights
Post by davers6 » Thu Nov 26, 2015 3:40 pm
Almost certainly the level sensor its on the near side front lower suspension arm they probably forgot to unplug it when engine removed or plug it back in when refitted
Chuds1
Re: Headlights
Post by Chuds1 » Thu Nov 26, 2015 11:47 pm
davers6 wrote:Almost certainly the level sensor its on the near side front lower suspension arm they probably forgot to unplug it when engine removed or plug it back in when refitted
Cheers Dave. It's def plugged in as it's an intermittent fault. I'll have a look over the weekend and see what's going on.
MB2
Re: Headlights
Post by MB2 » Sat Nov 28, 2015 1:55 pm
marc1 wrote:^ MB2 get a picture up as per FaisalJ's post above.
Won't be fully burned in yet as probably 20 hours on them but I hope this helps.
Users browsing this forum: No registered users and 257 guests
