How to fit a throttle cut defender..?
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
tartan_rob
Post by tartan_rob » Thu May 26, 2005 9:00 pm
Came home from hols today to find my uprated DV's and throttle cut defender were sat waiting for me. Only problem id that there is no intsructions for the throttle cut device. Anyone know how to fit this?
2017 Kawasaki Z1000
2014 RS6
2014 S1
Mik
RE: How to fit a throttle cut defender..?
Post by Mik » Thu May 26, 2005 10:56 pm
I have a set of instructions but its in word format....will PDF it and upload it to the downloads section
Mik
2014 Suzuka RS6
SimonS4MTM
Post by SimonS4MTM » Fri May 27, 2005 12:40 pm
What is a throttle cut defender?
Nordschleife
Post by Nordschleife » Fri May 27, 2005 1:12 pm
you can do this by reprogramming the ECU.
JonnyX
Re: RE: How to fit a throttle cut defender..?
Post by JonnyX » Fri May 27, 2005 2:48 pm
SimonS4MTM wrote:What is a throttle cut defender?
It clamps the MAP sensor output (kind of like a low pass filter). ME 7.1, as many have
posted, is a fairly clever system. If you exceed your requested boost by a certain
margin it will close the throttle plate to about %40 open. I think the MAP output is
used to calculate the load and therefore scale other parameters such as timing. e.g.
because the ECU thinks your load is lower it will let you run more timing (until knock
sensors interfere).
Mik
RE: Re: RE: How to fit a throttle cut defender..?
Post by Mik » Sat May 28, 2005 12:31 am
Quote from AW
"TCD interferes with the e-gas system as it alters the signal that the ECU would normally see from the boost sensor. Thus, the ECU cannot see the boost signal that the TCD blocks, nor can the ECU react to this boost if indeed it is a dangerous condition, say from a failure of the wastegate system, since it does not know it exists.
The same idea applies to the MBC, as the N75 wastegate solenoid action dictated by the ECU is being overrided by the mechanical bleed of the MBC."
Mik
2014 Suzuka RS6
smurfbus
Post by smurfbus » Sun May 29, 2005 8:42 am
If you want some engine safety with TCD you could put a MBC in paraller to control the max boost manually!
smurfbus
Post by smurfbus » Sun May 29, 2005 11:07 am
tartan_rob
Post by tartan_rob » Mon May 30, 2005 2:53 pm
Thanks guys. I have fitted both a MBC and the anti-throttle cut. What a difference. Car is electric and does not run above 1.2bar.....as MBC fitted boost should never exceed 1.2bar...? What a result.
2017 Kawasaki Z1000
2014 RS6
2014 S1
Verruckt
Post by Verruckt » Tue May 31, 2005 7:02 pm
smurfbus wrote:If you want some engine safety with TCD you could put a MBC in paraller to control the max boost manually!
Make that a must. Using a TCD without an MBC setup to control the spikes could result in disaster.
With an MBC, there is little risk involved.
-2001 Audi S4 biturbo (K16/K04 goodness @1.6 bar)
-2005 Golf V TDI PD
-1999 Jeep Cherokee Classic 4x4
www.NogaroBlue.com
Dippy
Post by Dippy » Wed Jun 01, 2005 12:50 pm
Verrückt wrote:
smurfbus wrote:With an MBC, there is little risk involved.
Low probability* but high severity. Few people have exactly the same qualification for risk.
*Assuming adequate installation and maintenance.
2001 Silver S4 Avant
Users browsing this forum: No registered users and 61 guests
