How to fit a throttle cut defender..?
tartan_rob
Came home from hols today to find my uprated DV's and throttle cut defender were sat waiting for me. Only problem id that there is no intsructions for the throttle cut device. Anyone know how to fit this?
2017 Kawasaki Z1000
2014 RS6
2014 S1
2014 RS6
2014 S1
RE: How to fit a throttle cut defender..?
I have a set of instructions but its in word format....will PDF it and upload it to the downloads section
Mik
Mik
2014 Suzuka RS6
- SimonS4MTM
- Top Gear
What is a throttle cut defender?
Nordschleife
you can do this by reprogramming the ECU.
Re: RE: How to fit a throttle cut defender..?
It clamps the MAP sensor output (kind of like a low pass filter). ME 7.1, as many haveSimonS4MTM wrote:What is a throttle cut defender?
posted, is a fairly clever system. If you exceed your requested boost by a certain
margin it will close the throttle plate to about %40 open. I think the MAP output is
used to calculate the load and therefore scale other parameters such as timing. e.g.
because the ECU thinks your load is lower it will let you run more timing (until knock
sensors interfere).
RE: Re: RE: How to fit a throttle cut defender..?
Quote from AW
"TCD interferes with the e-gas system as it alters the signal that the ECU would normally see from the boost sensor. Thus, the ECU cannot see the boost signal that the TCD blocks, nor can the ECU react to this boost if indeed it is a dangerous condition, say from a failure of the wastegate system, since it does not know it exists.
The same idea applies to the MBC, as the N75 wastegate solenoid action dictated by the ECU is being overrided by the mechanical bleed of the MBC."
Mik
Mik
2014 Suzuka RS6
tartan_rob
Make that a must. Using a TCD without an MBC setup to control the spikes could result in disaster.smurfbus wrote:If you want some engine safety with TCD you could put a MBC in paraller to control the max boost manually!
With an MBC, there is little risk involved.
-2001 Audi S4 biturbo (K16/K04 goodness @1.6 bar)
-2005 Golf V TDI PD
-1999 Jeep Cherokee Classic 4x4
www.NogaroBlue.com
-2005 Golf V TDI PD
www.NogaroBlue.com
Low probability* but high severity. Few people have exactly the same qualification for risk.Verrückt wrote:smurfbus wrote:With an MBC, there is little risk involved.
*Assuming adequate installation and maintenance.
2001 Silver S4 Avant
