Movit v Porsche brakes
2.7 V6 30v biturbo - 380 bhp
TarmacTerrorist
Post by TarmacTerrorist » Thu Apr 21, 2005 5:46 pm
Jani wrote:You may also need the splash plate of the discs, not sure whether the RS4 splash shield fits with the duct.
3D0 615 311C splash shield left
3D0 615 312C splash shield right
Not quite sure how they fitted onto the car but from what Carl was saying at the time it wasnt too difficult (they fit to the back of the hub somhow). Regards the splash plate, if your running with movits or the gmbh disc you need to take them off as they also stop air from cooling the disc. Carl had the ducts on his car still when he had his movits btw.
jani wrote:
The brake discs of Phaeton are only 345 mm, but maybe the cooling ducts can be modified to fit. Besides, the air intake is from the middle, so the difference in size shouldn't matter too much.
That is correct ,the disc size will not matter as the air is forced into the centre of the hub.
It's not the exposed surface of the disc that you are looking to cool down from the addition air, you actually want the veining to pick it up to give an even rate of cooling though out the disc. Some of the one I have seen on race cars have the ducts at the front of the car with flexipipe running all the way upto within a couple of mm away from the centre of the disk not the disk face.
cheers for the part nos ...
Too much is bad.
Plenty is better.
Jani
Post by Jani » Thu Apr 21, 2005 6:08 pm
Movits tend to rub to the splash shield anyway, as the discs are thicker (370x35mm). However, I've understood that the splash shields are obligatory so that the car is road legal. Surely depends on the country as well. And if discs are cross drilled, the wet weather water film won't be a problem.
Please, if someone installs or has these installed, post some pictures and experiences to the rest of us.
TarmacTerrorist
Post by TarmacTerrorist » Sat May 21, 2005 10:12 am
Jani wrote:Looking at Etka, it would appear you need the following:
3D0 615 447B -cooling duct left
3D0 615 448B -cooling duct right
As always, no guarantees the parts numbers are correct, or that they fit. Shouldn't cost too much if someone wants to make a prototype.
Just been past VW this morning and ordered up the ducting (7-10 days) -
part numbers (slightly different than jani posted)
3DO 615447D
3DO 615448D
for pheaton with disc size 364x34
Cost £8.58 + vat each (total £20.17)
Will let evryone know how I get on with them for fitting
Too much is bad.
Plenty is better.
DaveP
Post by DaveP » Sat May 21, 2005 10:13 am
Ordered mine too this week Gav...although I'm looking at another solution too...will post details on how I get on...
Found a picture of the Phaeton ducts on the RS4...
DaveP...
Audi Allroad - Daily slogger
S1 Exige - Track beast
Users browsing this forum: No registered users and 119 guests
