Ceramic disk refurbishment. Does this help?
Don't know if this helps anyone but a guy on the M3 forum has posted up about ceramic disc refurbishment at £700 approx per disc. Brings them like new allegedly.
http://forums.m3cutters.co.uk/showthread.php?t=127582
Re: Ceramic disk refurbishment. Does this help?
Wow, those moderators don't eff about over there, do they?ccfj1 on M3cutters wrote:You have pm mate.
Thread closed as needs to be a Site Sponsor.
Nope can't as it's really busybam_bam wrote:Wow, those moderators don't eff about over there, do they?ccfj1 on M3cutters wrote:You have pm mate.
- Surrey Sam
It only gets 3 posts a thread more than here which is self moderated.
I don't know what you mean?Surrey Sam wrote:It only gets 3 posts a thread more than here which is self moderated.
I understand with the warping of the steel brakes, but why would you need Ceramics skimmed?
I think it's instead of replacementOuttlaw wrote:I understand with the warping of the steel brakes, but why would you need Ceramics skimmed?
But if they needed replacing then you'd need to replace them?stuartk wrote:I think it's instead of replacementOuttlaw wrote:I understand with the warping of the steel brakes, but why would you need Ceramics skimmed?
I thought that Ceramic discs were weighed and measured to determine whether they needed replacing,
so if they needed to be replaced then there wouldn't be enough ceramic material to skim?
Any ideas anyone?
I don't really know a Lot about ceramics but apparently this refurb process means they can go againOuttlaw wrote:But if they needed replacing then you'd need to replace them?stuartk wrote:I think it's instead of replacementOuttlaw wrote:I understand with the warping of the steel brakes, but why would you need Ceramics skimmed?
Any ideas anyone?
Maybe they slap some more material on and then skim...
- Graeme4130
The process SICOM use (which is the company shown on the M3 Forum, is to skim the surface from the disc, and then relayer it with a new surface. It's the top layer on a Carbon Ceramic disc that provides the performance, the rest of the disc material is just there for weight saving and better heat dissipation. The cracks you see on a lot of CC discs is the surface finish and not usually the disc itself. If you crack the disc itself, it's funked, but the surface can be redone is my understanding
Ah, I now understand
Cheers Graeme
Cheers Graeme
Users browsing this forum: Majestic-12 [Bot] and 144 guests
