EBC Yellow Stuff
EBC Yellow Stuff
Hi all, so changed my pads and 100miles into bedding in process but my hat they squeak!!!!! Anyone else had same issue or does this go away?
KernowPete
Re: EBC Yellow Stuff
I was advised to apply a thin sheen of copper grease to the backs of the pads when installing mine to prevent this problem. They didn't squeal once.
2007 B7 RS4 Phantom Black Saloon - stock
Previous: Lightly modded Mondeo ST220 (great car), nothing else worth mentioning!
+1
I always copper grease my pads and I too have yellow stuffs that haven't squealed once.
Thanks guys, so copper grease the backside that's in contact with the Pistons I am guessing else I will wreck the disks?
I used to get horrendous squeaking on my previous cars brakes, used Ceratec paste on the rear of the pads & never heard a squeak again.
Misano Red| Black Optics| Black alloys| Black mirrors| Full CC at MRC| MRC Stage 2 Manifold| MRC Stage 2 Remap| De-Catted| KW V3 with H&R Fr & rear ARB| H&R Hubcentric spacers 8mm Fr, 10mm rear| A few choice CF goodies to go on|
KernowPete
Yep, a thin sheen on the BACKs of the pads. My yellowstuffs came with anti-squeal shims attached on the backs and I just smeared the grease on top of them. The shims are designed to stop the squealing but don't always work - the copper grease certainly did.hlbeckley wrote:Thanks guys, so copper grease the backside that's in contact with the Pistons I am guessing else I will wreck the disks?
As said, on the backs. I also put a very thin smear on the top and bottom edges and also a smear on the chrome retaining plate where it contacts the tops of the pads. Basically on any surface that contacts the calipers. BUT never on the face or front of the pad.
audi_do_dat_den
I copper greased the backs of my yellows and even after 400 miles they squeal but only on slow town driving.... which is a little irritating and embarrassing....
If the dont settle down, theyre going to be frizbee'd into the bin and OEM will go back in.
They were put in at the same time as putting new discs on.... so the perfectly flat new disc surface might be trapping dust.
Cant fault them for stopping power though.
rwilsonrs4
i fitted yellows to mine with a smear on coppaslip on the backs , not a single squeek since fitted so dunno what the problem is with yours
1/4 mile 12.01 secs 123.5mph
I have Yellows all round. I didn't fit any of them myself though, had them done at 2 different garages, so I can;t say if they used copper grease but I assumed they did as it is a common practise.
No noise when the fronts were fitted. I had a little squeaking from the rears for the 1st 30 or 40ish miles then it stopped and never returned.
- RossDagley
- Top Gear
Fitted yellows myself front and rear on the b7. Always copper grease back of all pads generally even if they have shims.
Never had squeal from them. All good
Previously:
Previously:
I believe the squeak is normal for the first app. 500kms with EBC pads. I did proper copper pasting and still had this in the beginning.
I think the conditions of discs influence greatly on this. Mine were skidded when pads fitted.
Daytona Grey B8.5 & Guards Red 981 / Ex.Audi RS4 B7 Sedan, Daytona Grey.
Disks are about 2000 miles old so I guess pads need to bed to the surface
I think copper grease may be needed as now the are clacking a bit too
Will get there eventually
Users browsing this forum: GhiniRS4 and 184 guests
