EBC Yellow Stuff
hlbeckley
EBC Yellow Stuff
Post by hlbeckley » Sat May 09, 2015 8:58 am
Hi all, so changed my pads and 100miles into bedding in process but my hat they squeak!!!!! Anyone else had same issue or does this go away?
KernowPete
Re: EBC Yellow Stuff
Post by KernowPete » Sat May 09, 2015 9:11 am
I was advised to apply a thin sheen of copper grease to the backs of the pads when installing mine to prevent this problem. They didn't squeal once.
2007 B7 RS4 Phantom Black Saloon - stock
Previous: Lightly modded Mondeo ST220 (great car), nothing else worth mentioning!
RS6BRIT
Post by RS6BRIT » Sat May 09, 2015 9:28 am
+1
I always copper grease my pads and I too have yellow stuffs that haven't squealed once.
hlbeckley
Post by hlbeckley » Sat May 09, 2015 9:51 am
Thanks guys, so copper grease the backside that's in contact with the Pistons I am guessing else I will wreck the disks?
gilly
Post by gilly » Sat May 09, 2015 9:56 am
I used to get horrendous squeaking on my previous cars brakes, used Ceratec paste on the rear of the pads & never heard a squeak again.
Misano Red| Black Optics| Black alloys| Black mirrors| Full CC at MRC| MRC Stage 2 Manifold| MRC Stage 2 Remap| De-Catted| KW V3 with H&R Fr & rear ARB| H&R Hubcentric spacers 8mm Fr, 10mm rear| A few choice CF goodies to go on|
KernowPete
Post by KernowPete » Sat May 09, 2015 10:50 am
hlbeckley wrote:Thanks guys, so copper grease the backside that's in contact with the Pistons I am guessing else I will wreck the disks?
Yep, a thin sheen on the BACKs of the pads. My yellowstuffs came with anti-squeal shims attached on the backs and I just smeared the grease on top of them. The shims are designed to stop the squealing but don't always work - the copper grease certainly did.
RS6BRIT
Post by RS6BRIT » Sat May 09, 2015 11:11 am
As said, on the backs. I also put a very thin smear on the top and bottom edges and also a smear on the chrome retaining plate where it contacts the tops of the pads. Basically on any surface that contacts the calipers. BUT never on the face or front of the pad.
audi_do_dat_den
Post by audi_do_dat_den » Sat May 09, 2015 7:36 pm
I copper greased the backs of my yellows and even after 400 miles they squeal but only on slow town driving.... which is a little irritating and embarrassing....
If the dont settle down, theyre going to be frizbee'd into the bin and OEM will go back in.
They were put in at the same time as putting new discs on.... so the perfectly flat new disc surface might be trapping dust.
Cant fault them for stopping power though.
rwilsonrs4
Post by rwilsonrs4 » Sat May 09, 2015 7:40 pm
i fitted yellows to mine with a smear on coppaslip on the backs , not a single squeek since fitted so dunno what the problem is with yours
1/4 mile 12.01 secs 123.5mph
Post by MikeFish » Sat May 09, 2015 8:05 pm
I have Yellows all round. I didn't fit any of them myself though, had them done at 2 different garages, so I can;t say if they used copper grease but I assumed they did as it is a common practise.
No noise when the fronts were fitted. I had a little squeaking from the rears for the 1st 30 or 40ish miles then it stopped and never returned.
RossDagley
Post by RossDagley » Sat May 09, 2015 11:54 pm
Fitted yellows myself front and rear on the b7. Always copper grease back of all pads generally even if they have shims.
Never had squeal from them. All good :)
Previously:
rob-s
Post by rob-s » Sun May 10, 2015 6:24 am
I believe the squeak is normal for the first app. 500kms with EBC pads. I did proper copper pasting and still had this in the beginning.
I think the conditions of discs influence greatly on this. Mine were skidded when pads fitted.
Daytona Grey B8.5 & Guards Red 981 / Ex.Audi RS4 B7 Sedan, Daytona Grey.
hlbeckley
Post by hlbeckley » Sun May 10, 2015 9:26 am
Disks are about 2000 miles old so I guess pads need to bed to the surface
I think copper grease may be needed as now the are clacking a bit too
Will get there eventually
Users browsing this forum: GhiniRS4, Google [Bot] and 124 guests
