OBD Port Car Theft
Moonmonkey831
Re: OBD Port Car Theft
True it's not fool proof and you'd be unlucky if it happened to get nicked whilst on a flight, but also the last flight I was on had wifiboff wrote:Cool plan, but what if that happens whilst you are inflight?
Current: 2017 RS6 Performance in Nardo Grey
Previous: 2014 RS4 in Sepang Blue; 2011 Q5 3.0TDi Sline Plus in Ibis White; 2007 Audi S5 4.2 V8 in Phantom Black; 2006 VW Golf GTi in Tornado Red; 1998 VW Golf 1.9 TDi in Navy Blue; 1988 VW Polo 1.0 in Gold
Chuckle, so now to be sure -
1) upgrade the home alarm
2) ensure cctv fitted at home
3) ensure you park it under cctv
4) block obd port
5) repurpose an iphone
6) install a tracker
7) learn to box
only fly on planes with wifi
4) block obd port
7) learn to box
Zero Drama
4) block obd port
7) learn to box
buy a crook lock
4) block obd port
7) learn to box
- Graeme4130
Get a shot gun
Hire a big angry dude
Leave a big <beep> on the dash board
On a serious note there has been no mention of lasers yet, which upon reflection i find most disappointing.
Zero Drama
I fitted a system to my B8 RS4 to stop this as my car is parked on the drive. It is basically a GPS tracker that cuts the starter circuit and only closes the circuit and allows the vehicle to be started once a wireless tag is in the car.
I keep the tag separate to my car keys and the car doesn't start without the tag! It works a treat! Even if they strip the car and remove the tracker (which would take hours) the car still won't start!
They came to my work to fit the system in around 2 hours....helps me sleep at night!
I like the sound of this, can you give us some more info on price and who fits them
If you forget about the GPS bit its just a bog standard immobiliser that we all used to have on our cars 20 years ago before the manufacturers started building the immobiliser transponder into the key.
Who remembers the Vecta immobiliser? I was a trained installer for them and you couldnt get insurance on a Cosworth without one back in the day. Clever immobiliser mainly due to the way they taught us to install and cut vital circuits like the power to the ECU, feed to the starter relay, fuel pump and even headlights as most cars were stolen at night and that would bring more attention from the police if seen driving at night. You could also wire the horn to the starter switch so if anybody tried turning the key (or screwdriver) while the immobiliser was active it would sound the horn.
Yup, I remember Vecta. It was the upside down triangle window sticker wasn't it? They were fitted to Cossies and higher end cars. I had the Clifford immobiliser on my car, which was a version that worked via a jellybean transponder on my key ring that you didn't have to plug into the dash.MikeFish wrote:If you forget about the GPS bit its just a bog standard immobiliser that we all used to have on our cars 20 years ago before the manufacturers started building the immobiliser transponder into the key.
I had that as well as a TOAD alarm.
The things I did to protect a Corsa GSi!
'15 B8 RS4 - SOLD
- Graeme4130
I had a sapphire cosworth. It had a little circular fob with three metal studs in it that you pushed into a receiver on the steering column before you could start itkmpowell wrote:Yup, I remember Vecta. It was the upside down triangle window sticker wasn't it? They were fitted to Cossies and higher end cars. I had the Clifford immobiliser on my car, which was a version that worked via a jellybean transponder on my key ring that you didn't have to plug into the dash.MikeFish wrote:If you forget about the GPS bit its just a bog standard immobiliser that we all used to have on our cars 20 years ago before the manufacturers started building the immobiliser transponder into the key.
Not sure what brand it was, but it was thatcham approved for the insurance
Those cars used to get stolen a lot back then
Users browsing this forum: Bing [Bot] and 345 guests
